Question about 4moms Mamaroo Infant Seat
MamaRoo fails to rotate - 4moms Mamaroo Infant Seat
What is code 67 on a LG PTAC
Hi Jason, The link below is a web page, Click the 4th down for an LG Ductless HVAC & PTAC Error Codes manual.....
https://www.google.com.au/search?q=LG+PTAC&oq=LG+PTAC&aqs=chrome..69i57j69i61&sourceid=chrome&ie=UTF-8#q=LG+PTAC+error+codes
Code 67 ODU fan motor not rotating or proving rotation. Verify fan motor plugged in correctly & fan rotates freely. This can be a failed motor, failed board or motor could have failed and caused board failure as well. Verify 310V DC on motor wires separated by empty terminals on plug with motor plugged in, 0V DC = failed PCB, 310V DC = likely failed motor. Next step: Unplug motor and manually spin the fan (keep it spinning): on same wires you just tested, 0V DC indicates motor failed and caused board failure. 14-30V DC indicates a good motor
Mar 31, 2016 | LG Heating & Cooling
What does FO2 MEAN ON PANASONIC MOVIE CAMERA
. Error Codes Panasonic JVC Description F01 . No Take-Up reel rotation F02 E03 No Supply Reel rotation F03 E02 Mechanism has not unloaded to the Eject position F04 E01 Mechanism has not fully loaded up to the stop position F05 E04 Rotation of the video head has stalled or too fast . E06 Tape drive motor is not rotating or stalled F31 . Data Transmission error F51 . Focus drive motor is not functioning, no focus. Color F52 . Zoom drive motor is not functioning, no zoom U10 . Dew Sensor has detected condensation or failed U11 . Video Heads have been detected as clogged failed
Nov 14, 2014 | Cameras
Something's preventing the blade from rotating
burn up, or the blade is so warn its in lockmode, perhaps if that's not it, and you recently changed the blade make sure that is was put on correctly, and the guard is not hung up
Jan 28, 2014 | Skil 5250 Circular Saws
Dishwasher DD605 f2problem motor has been replaced
Hi.
F2 means "Motor rotation not sensed". If the motor has already been replaced , then either the hall sensor that detects the rotation is not working, the rotor is jammed, the control board is defective, or there is a wiring problem.
• Foreign object has jammed the rotor.
• The rotor has failed.
• Hall sensor connector or wiring fault at hall sensor or controller.
• The hall sensor has failed.
• Motor stator winding or connection open circuit.
• The electronic controller has failed.
• PCB mains filter has failed.
Feb 05, 2012 | Fisher and Paykel Dishwashers
My grinder starts slowly and takes time to build up to speed. It is a model 612 and does not appear to be a capacitive start motor. All I can see under the base plate is a relay. Thanks for your...
Hi and welcome to FixYa, I am Kelly
Inside your grinder either the stationary switch or the rotating assembly that actuates the stationary switch has failed.
Download this pdf file:
http://www.baldor.com/pdf/literature/CA506_0806_WEB.pdf Then go to page 9
The rotating assembly is this part number: (most common failure)
34RS2060SP
You must remove the end plate / cap to change this part.
The statonary switch rarely fails unless the rotating assembly damaged the contacts when the rotating assemble failed. When the rotating assembly fails you often find a spring and flyweight loose inside the grinder during disassembly. Should your stationary switch have failed try and get a number off of it so you can get the right switch. Otherwise you have to use NEMA code / Body type numbers.
Thanks for choosing FixYa,
Kelly
May 06, 2011 | Baldor 612 6" Bench Grinder 3600 Rpm Stamp...
The bagless rotor does not rotate/sweeper does not rotate
There is no rotor inside the clear container that turns on a DC07. The stuff spins due to the shape of the airflow. Perhaps your cyclones are completely clogged. you can clean them yourself. see this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Jul 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
F01 error on playback or recording - Panasonic NV-DX100
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila mattik1999@yahoo.com
Jul 11, 2009 | Panasonic Video Cameras
Timer doesn't move from any position. Heater doesn't active.
HI. this is a failed timer mechanism. replacing this failed timer control module will restore normal functions.
The timer is designed to rotate, via the timer motor. if this mechanism is defective or, not rotating this timer mech, this will render the timer useless. the timer has failed.
Jun 16, 2009 | Whirlpool LGR4600 Gas Dryer
4moms Mamaroo Infant Seat Logo
82 people viewed this question
Top 4moms Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a 4moms Baby Gear Expert? Answer questions, earn points and help others
