I have a JVC turntable and an old Sansui reciever. Last night I was playing a record, and it stopped playing out of one speaker, and makes a loud buzzing noise. However, when I push the Mono button
I had a similar problem with a much older turntable some years before, but it went away when I hooked up this newer (but still quite old) turntable. The needle may have been dropped as right before this happened a kid was goofing with the turntable.
  • Audio Player... Master
  • 5,056 Answers
You should check the connections to the turntable, it sounds like it might be feedback hum, caused by a wire touching or something like that. Don't forget to check the connections to the cartridge too.
Posted on Mar 15, 2014
djproaudio
  • 515 Answers
SOURCE: my 1200 is making a loud buzzing noise!
Yes, that large metal box is the housing for the transformer. Not too hard to replace, but if not done properly can cause serious damage to your turntable.
I've never heard of a transformer on these units causing a buzzing noise. Did you buy this used or new? If it's new, it's highly unlikely that the issue is with the transformer. However, we have been seeing some 'unusual' issues with Technics 1200s lately, which we attribute to a decline in quality standards @ Matsushita (Technics parent company).
The transformer can be purchased HERE. There really isn't much to replacing this part, just put it back exactly as you took it apart. Take pictures along the way, to help you if you get stuck. Also take some notes on where each part goes.
If you get stuck along the way, feel free to give us a call. Our service techs are masters with the 1200s, and we can walk you through it: 1.866.668.1596 ext 1
- DJ PRO LAB
www.DJPROLAB.com
Posted on Apr 30, 2008
djproaudio
  • 515 Answers
SOURCE: turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
Posted on May 13, 2008
djproaudio
  • 515 Answers
SOURCE: JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
Ganx
  • 113 Answers
SOURCE: I just inherited an old Zenith console turntable
Hiya, check and be sure the turntable is plugged into correct inputs, "phono"
If thats OK, then probably is the stylus but could also be the cartridge itself. Check the wires on the back of cartridge make sure they are fixed properly. If all Ok, then start with a new stylus first.
Hope it helps
Posted on Jul 25, 2009
  • 124 Answers
SOURCE: Record player - sound only plays out of one speaker
Your tracking and anti-skate are not set correctly.
If you have the manual for this unit, it should have directions for setting these.
Posted on Sep 12, 2009
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Jan 11, 2008 | Audio Players & Recorders
Why did it stop revolving?
The driving element, be it belt or rubber puck, may have failed. It's not an unusual failure in a turntable that is several years old and rarely used.
Jan 08, 2016 | Audio Players & Recorders
Plugged in my old jvc turntable and i can't hear sound coming from the speakers. Any idea what is wrong?
!0 Try if you can and play a record on another amplifier Those were "HiFi" players and the output from the cartridge is max 5/1000 volts which is tiny for aux inputs so you will have to use a pre- amplifier to boost this miniscule output to "Line" levels. Check yourbstilus when was it last replaced?
Aug 20, 2014 | Audio Players & Recorders
The record plays but it is really quiet, how do i turn up the volume?
You should check that it is plugged into a socket in your amp that is designed for record decks. If the amp does not have a dedicated socket, then you need to get a magnetic cartridge pre-amp. The record deck plugs into that and that goes into your amp. That will make the deck as loud as the other sources, such as CD players etc.
Jun 24, 2013 | JVC AL A158BK Turntable
My DA-T500 is stuck on Tape and wont change to turntable or radio
You might have a gummed up switch. Try some contact cleaner and go from there.
Apr 29, 2012 | Computers & Internet
Bass speaker moving in out more then normal
If you can't hear the difference maybe the bass frequency which is moving the speakers is below your hearing range.
I think you may have a "loudness" button on that amp -- if you do, turn off the loudness -- this is a bass booster.
But, in general, bass speakers are designed to move in & out a lot. They have to move a lot of air to produce the bass sound.
May 09, 2009 | B&W ASW1000 Speaker
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
50Hz noise appears at the end of the disc
HAVE YOU GOT ANY OTHER EQUIPMENT CONNECTED IF SO DISCONNECT THEM THEN JUST USE THE AMP,DECK AND SPEAKERS AND MAKE SURE THERE IS NOTHING ELSE PLUGGED INTO THE SAME CONNECTING LINE
THEN ADD THE OTHER ITEMS ONE BY ONE
DEREK
Nov 16, 2008 | Philips gemini XL-500 II Turntable
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
61 people viewed this question
 Grubhead
Grubhead
