Question about Irons
How to replace the rowenta professuonal dx8800 power cord
5 Suggested Answers
geokohler
  • 304 Answers
SOURCE: Repairing a Rowenta DX8800
It sounds to me like the thermal cutoff switch has blown. Irons have these as a safety device similar to a fuse to protect against fire in the event the iron gets too hot. These are not very costly to replace. Here is a link to where you can buy them:
http://www.welco.com.cn/?gclid=CJiWv7TN2ZQCFQpzHgodl1LXQQ
, Make sure you get one of the exact same cutoff point as the one designed for your Iron. If you put in a higher temp device it will be harder to blow but will make the iron dangerous as it may cause a fire if it over heats. Some shady repair men will just bypass this and the iron will work again fine but this is a dangerous practice as it directly puts you of danger. If you do have it repaired at a shop demand for the old thermal cutoff from your unit when you drop it off so the tech will know you know what is wrong with it and that you will check to make sure that it has really been changed. This will also not give him the chance to over charge you when he knows you know it is only a 1 dollar part and easy to change.
This device is very easy to change, If you can open your iron you could easily do this yourself. The part, as you will see on the site where you buy them, only has 2 wires one comming out of each end. You simply cut out the old 1 and replace it with the new one. You do not even have to worry which end goes where. It is like a fuse, it works the same either direction. You have to buy some wire crimp connector to connect it, you can not just solder it in due to the heat in the iron. In a pinch you could just securely twist the ends of the leads with the leads from the old cutoff if you clip the leads from the old cutoff real close to the device. This will leave you with plenty of wire to get a good twist. I always use the crimp connectors so it looks more professional.
Anyway, I hope you found this to be helpful and if you need more help feel free to ask me. I will stay with you on this until we have it fixed.
George
Posted on Jul 24, 2008
  • 4088 Answers
SOURCE: how do I clean a rowenta DX8800 iron that leaves deposits on my g
Use a white vinegar and distilled water solution in the iron, but don't do any clothes with it. Let it soak for a while, then heat the iron and let it blow out any debris. Fill again with distilled water, shake well, and let it steam out. Do this again until there is no vinegar smell coming out. If you use only distilled water, you should have no further problems like this.
Posted on Sep 18, 2009
maintenacemi
  • 95 Answers
SOURCE: water leaks
poly seal{white} perished where comes from tank to element plate
Posted on Nov 18, 2009
SOURCE: Power cord sparked and burnt. What tool do you
They are called TORX screws. You need a torx set of drivers.
Posted on Feb 12, 2010
How do I put water in it (dx8800) ? I see a slider but don't want to break it.
the manual says to slide to left you can download manual at rowenta.com customer service on irons 8000 series
Sep 23, 2011 | Rowenta Professional DX8800 Iron
I NEED A NEW ELECTRIC CORD, CAN I BUY ONE AND DO THE REPAIR MYSELF THE IRON IS 5 YEARS OLD
Chances are you will only need to replace the end and that is fairly easy to do.Buy one from a local electrical or a hardware shop.It should come with instructions or you can Wiki How it.
Aug 05, 2011 | Rowenta Professional DX8800 Iron
Cost of this iron?
"Cost of this iron?"
Rowenta DX-8800 1750-Watt Professional Iron
The list price is around $130.00
Apr 01, 2011 | Rowenta Professional DX8800 Iron
How do I clean a rowenta DX8800 iron that leaves deposits on my garments
Sep 18, 2009 | Rowenta Professional DX8800 Iron
Bad link
Hello, can you clarify the problem, this didn't go to George, who is that? what do you need? how can I help you?
Oct 25, 2008 | Rowenta Professional DX8800 Iron
Rowenta DM 273 Iron
It is a Torx tamper proof screw-call 925-827-1011 and order a "Rowenta tool" $10.00 plus shipping this place allso sells Rowenta parts
Jun 13, 2008 | Rowenta Professional DX8800 Iron
Doesn't heat up...
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Nov 01, 2007 | Rowenta Professional DX8800 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Irons Logo
37 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
