Question about Antec TruePower Quattro 850-Watt Power Supply
Computer power supply does not work
Computer froze had to unplug it. Now computer will not start. I think it is the powersupply because I have checked the power source and the power switch on the back of the power supply.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Posted on Dec 25, 2014
4 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: No Power
take off the hard drive and the meories. fire it up. if it comes up , replace the item you taken off one at a time. you will find the porblem.
Posted on Oct 16, 2008
  • 45 Answers
SOURCE: computer won't start
The power supply is fried partially, or the motherboard went poof.
Posted on Dec 21, 2008
rulds2008
  • 3866 Answers
SOURCE: Nothing on my computer was working. Screen and
This has to be plugged into a motherboard and the switch to it as well is controleed by motherboard so no it will not come on just by applying power. I would try another supply for you inital issue if that does not turn on then what you got here is a cable backwords or a motherboard malfuction of some type.
thanks if this helps please rate it.
Posted on Dec 19, 2009
My dell optiplex gx270 froze now will not come back on
Here try my trouble shooting steps. Some I usually follow this when I can't get a power up. My no-boot flow chart has always worked for me (many years work for Gateway tech support has paid off).
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Hope this works. I am thinking the ram is probably toast. We will see.
Brian
Jul 09, 2009 | Dell OptiPlex GX270 PC Desktop
After i turn on my machine i was get stuck within seconds ....PLZ Help me?
Can you get to windows at all or does the PC just not POST. Well I am assuming it tries to load windows.
I would see if you can go into safemode first. You may have a software problem.
If you can get into safemode then I would do this:
I would boot up to safemode (assuming that works) and type MSCONFIG in the run box. Check selective startup, then go to the selective start up tab and uncheck everything.
Click apply or ok.
Restart the PC and let windows load normally. If it does, then one of the things you unchecked was causing the problem.
I would then open the MSCONFIG again (can do this without entering SAFE mode for now). And then check one thing back at a time and restart the PC. If it hangs up on the last thing you unchecked than you have your answer.
Go back to safemode and uninstall whatever was causing the hangup.
If you think it is hardware then try these steps.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit.
Jul 08, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
My computer keeps booting every 2 seconds and I just can see motherboards first screen during 1 second then cant see anything else
I am almost positive it is the ram, because it gets to windows but crashes after loading windows partially. I once had a similar problem. Just make sure all the Power Supply connectors are properly connected.
Try these steps too:
Jul 07, 2009 | Intel D865GBF Motherboard
My hp a345c will not turn on. It has a flashing
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PCbuilder and the warranty is expired you can take out the bios chip andsent it someone who reprograms BIOS chips or you can buy a brand newchip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1.Full power down. Unplug the power cord from the Power supply. Then holddown the pc power button (this discharges any residual power in thecapacitors).
3.Take out one of the RAM sticks if there is 2 or more. Swap the RAMsticks in different RAM slots. Try one stick at a time to see if youcan get the PC to boot. If this works, then the remaining ram sticksare damaged.
4. Set the Cmos jumper to clear. Power up the pc.Power down the PC. Set the Cmos jumper back to normal position, powerup the PC.
6.Check the powersupply function. Either by a powersupply voltage checker(20-25 dollars at local PC shop), get the supply tested at a PC shop(usually a free service), put the powersupply in a different pc, or trya different powersupply in the problem computer.
Ifthe Powersupply checks out ok, then you will have to do a process ofelimination to find out what part or parts are the culprit of theNo-Boot.
Takeout one of the RAM sticks if there is 2 or more. Swap the RAM sticks indifferent RAM slots. Try one stick at a time to see if you can get thePC to boot. If this works, then the remaining ram sticks are damaged.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives,other PCI cards. Do this one at a time until you find the culprit. If aPOST screen, meaning you can see Anything from the PC brand name toMotherboard brand name appearing on the screen.
Jul 07, 2009 | HP Pavilion Replacement 200w Micro ATX PS3...
Won't power up-- suppply OK
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Jul 06, 2009 | Acer Aspire L100 PC Desktop
Errore codeoxe0000227
Try to boot the pc.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Screen went dead, unplugged the graphics card and
Try to boot the pc.
If the video card is suspected to be damaged, try it in a other pc (friend's, mom's or dad's, pentagons' ).
if it is bad, there is your answer.
Jul 06, 2009 | XFX Computers & Internet
Flashing orange light on front of my dell 5150 desktop, will not turn on, even after unplugging for one hour. when plugged back in, flashes orange, no fan, no power. JK
Try to boot the pc.
Jul 05, 2009 | Dell Computers & Internet
I HAVE A COMPUTER WITH CONFIGURATION OF INTEL EXTREME DP45SG MOTHERBOARD,QUAD CORE 6600 PROCESSOR,NVIDIA GRAPHIC CARD,DDR3 RAM(1333 HZ),500GB HDD(SEAGATE) and still my compuer screen shows NO DISPLAY...
Try to boot the pc.
Ok try all this first...
Feb 27, 2009 | Dell Dimension 4600 PC Desktop
Antec TruePower Quattro  850-Watt Power Supply Logo
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Julie Endres
Wahs Team
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
