Question about Spec-D 06-09 Volkswagen Golf V / GTI Tail Lights - Chrome pair
Won't start, rapid clicking noise - Spec-D 06-09 Volkswagen Golf V / GTI Tail Lights - Chrome pair
Renault Grand Scenic - Dashboard flashing red light, clicking noise throughout car.
Hey,
You can try another battery if you have one, or take the battery to be tested somewhere to see if its at fault
Thanks,
Ekse
Sep 04, 2008 | 2005 Renault Sportwagon
My starter won't work just one click noise when I try start my harley
A LOUD single click, sounding the the started is initally engaging and then does nothing?....that would be a bad starter clutch.
Is it a fairly loud rapid clicking noise like a machine gun?....that would be low battery CURRENT to starter, faulty battery.
Is it a quiet single click?....that would be a bad starter relay
Mar 30, 2013 | Harley Davidson Motorcycles
Van won't start,rapid clicking heard when key is turned. need help/directions replacing starter relay for gmc vandura 2500, 1991
Check battery connections and battery fuse. Battery may not be large enough for the size of your van
Jan 18, 2013 | GMC Cars & Trucks
2004 ion won't start. Lights work. When I turn key don't get series of clicks, get one snap.
That symptom usually means the solenoid on the starter is bad and no longer is completing the circuit to engage the starter. A new starter will likely solve that issue. A series of rapid clicks would indicate a week battery. You can try repeatedly turning the key to the start position rapidly, sometimes the starter wil start working. You can also try tapping the starter while somebody holds the key in the start position, if the starter engages place it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 16, 2011 | Saturn Ion Cars & Trucks
Car won't start. Makes a rapid clicking noise when ignition is in start position
The rapid clicking noise is caused by low battery voltage, you eiother have rub the battery down or the battery is defective or the battery cables are loose or corroded
Dec 20, 2010 | 2004 Pontiac Grand Prix
Won;t start makes rapid clicking noise
Sounds to be a loose battery terminal or battery wire lead. Verify that the headlights are bright when turned on if so battery is not dead.
Nov 04, 2010 | 2004 Jeep Liberty
Rapid clicking noise coming from under the dashboard.
If you have a tape cassette player in the dash, this can cause a sound like what you are describing. Even though a tape is not in it,,, it can still freak out and cause this sound. Had this happen on several of my old vehicles. Let us know if this helps. Leave feedback for others to see. Thanks.
Nov 08, 2009 | 1995 Nissan Altima
Spec-D 06-09 Volkswagen Golf V / GTI Tail Lights - Chrome pair Logo
Top Spec-D Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Spec-D Golf Expert? Answer questions, earn points and help others
