Question about New Balance Exercise & Fitness
Console display on new balance 9.0e elliptical doesnt work
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My weslo momentum 7.0 ex elliptical machine display stopped working. It won't power on even with new batteries.
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of the pedalsto the crank axles.
ernesto cuadramanagua, nicaragua
Posted on Mar 10, 2012
My Nordic track elliptical audio strider 800 console does not work. I have changed batteries and I have purchased the adapter and still does not work. What can I do?
Better to buy a new console. It would be difficult to repair the existing console.
I'd you wish to get some details about elliptical repair then check the below added link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | Nordic Track Exercise & Fitness
Precor elliptical says stuck key on upper display and sometimes flickers or doesn't even turn on at all.
A stuck tek generally means the hard overlay (with buttons) is faulty. I have seen where the entire console needed to be changed. The battery may have also been bad but this would have been for the flickering only.
877-805-1030
Book An appointment
Mar 09, 2016 | Exercise & Fitness
Vision fitness X1400 elliptical thinks it's a bike
Check for a switch on the back of the display - you will need to remove the display to get at the switch.
Aug 30, 2014 | Exercise & Fitness
No resistance for Healthrider H90E elliptical
More than likely your going to need a console...If you checked all the power from the console down to the resistance motor and that's good then console is bad.
Dec 08, 2013 | HEALTHRIDER H90E Elliptical Console Model...
I bought a second hand Proform 14.0 CE elliptical. The incline is stuck at about 20 degrees. The incline ramp moves slightly while trying to calibrate but remains about 20 degrees. The display shows that...
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Oct 24, 2013 | Exercise & Fitness
Proform Elliptical 1050E - Display blinking / going out
you may need a new overlay or console. Call Treadmill Doctor at 800--750-4766 and they can trouble shoot it for free!
Jul 11, 2012 | Exercise & Fitness
Mar 07, 2012 | Exercise & Fitness
Why does the resistance on my elliptical randomly go to OFF while working out
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Dec 06, 2011 | Exercise & Fitness
Change batteries in consol of elliptical, but still the resistance or tension does not change or increase
their maybe a loose connection between the upper display and function controls I would pull apart the upper display and check the connectors between the two boards
Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
Find repair service for schwinn treadmill
short of changing batteries ,if you got them, theres nothing you could do other then replace it, If your speed rpms and distance doesnt read its the speed sensor
Feb 03, 2009 | Schwinn 430 Elliptical Trainer
Exercise & Fitness Logo
100 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
