Question about LG LSN121HSV/Y3328 11,200 BTU INDOOR MINI-SPLIT HEAT PUMP FAN COIL R-410A
Cooling light flashes 5 times and no heat - LG LSN121HSV/Y3328 11,200 BTU INDOOR MINI-SPLIT HEAT PUMP FAN COIL R-410A
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
Model A12AWU-UF7
That is an alert code. Most heaters require forced air venting, and some use a vacuum switch to test for that airflow before igniting gas flame.
May 07, 2014 | Heating & Cooling
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Red light flashing
if you check the inside of your furnace panel theirs a section where it says notes that should point you in the right direction. If you find it that will give me more info also do give you more advice
Jan 11, 2014 | Ruud Heating & Cooling
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
Problems with frigidaire affinity dryer model gle02152es1.
Hello ljdixon226 - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
"cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Sep 20, 2009 | Heating & Cooling
LG LSN121HSV/Y3328 11,200 BTU INDOOR MINI-SPLIT HEAT PUMP FAN COIL R-410A Logo
57 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
