Question about General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator
Kenmore side freezer won't latch - General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator
My Kenmore side by side Model 59502990 fridge door opens when you shut the freezer
The refrigerator door latch may be defective or weak. If the latch is not repairable, replacement may be the only solution
Feb 14, 2013 | Refrigerators
Freezer gets to cold thermostat won't adjust
Prepare to replace the t'stat. At least it is freezing and you haven't lost anything.
Jan 26, 2013 | Kenmore Elite Side By Side Refrigerator -...
Kenmore H4 not starting
Check the door latch. If the door doesn't latch, the dryer won't start
Oct 03, 2012 | Kenmore Elite HE4 Electric Dryer
KENMORE REFRIGERATOR WON'T COOL ON BOTTOM BUT FREEZER WORKS BUT HAS ICE ON BACK WALL
needs fan replaced, there are a couple of plastic strips down the sides of the bottom plate, remove those to expose screws remove bottom pan then back wall fan will unclip from wires local appliance store should have one avaiable
Jul 04, 2012 | Kenmore Refrigerators
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
Ice maker in side by side Kenmore refrigerator model number 106.55529400 has stopped working.The ejector fingers are not stopping in correct position,from what I have read online this means ice maker...
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
.2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope i can help you with your problem.
Have a nice day : )
Aug 22, 2011 | Kenmore Refrigerators
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator Logo
12 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
