Question about Shoprider Streamer Sport Power Wheelchair 888WA- Used Power Chair
How do i take the seat off - Shoprider Streamer Sport Power Wheelchair 888WA- Used Power Chair
2007 SRX pedals, adjustable quit, front drivers seat and both heater switches All quit at same time what could have done this? Passenger power seat still works?
Electronic's ! drivers Power seat module , driver door module . Do you know anything about automotive electronic's ?
The heated seat module (MSM) controls heated seat operation for both the driver and passenger seats. There are 2 modes of operation available for heated seats; both the seat cushion and seat back heat, or seat back only heat. When a heated seat temperature signal request is received, the MSM will activate both the seat cushion and seat back heating elements. When the heated seat BACK ONLY mode button is pressed once the MSM will deactivate the seat cushion heating element and leave the seat back heating element ON.
The adjustable pedal system is controlled by the memory seat module (MSM).
your best bet , have a qualified repair shop check it out ! Could have DTC'S - diagnostic trouble codes in door module , BCM etc...
Mar 15, 2018 | 2007 Cadillac SRX
Seat won't move forward, cant get to the rear bolts to remove seat because seat is back as far as it can go is there any way to move the seat manually
You must remove the seat from the power seat transmission then remove the drive motor from the seat transmission, move the seat to the desired position and reinstall the motor to lock it in place. The seat transmission is bolted to the seat mounting bracket/rails.
Feb 01, 2017 | Seat Cars & Trucks
Seat heater comes on by itself in 2004 yukon denali
Heated Seat Components
The heated seat system consists of the following components:
• Driver and passenger heated seat switches
• Driver and passenger seat back heater elements
• Driver and passenger seat cushion heater elements
• Driver and passenger seat back temperature sensors
• Driver seat module
• Driver door module
• Passenger door module
When there are modules involved in the operation of any componet that's acting up , the module's electronic's could be the culprit ! But without testing who's to say what the problem could be !
I would have it check for DTC'S
DTC B2425 or B2430
The driver and passenger seat heaters are controlled by the driver seat module. Power is supplied to the driver seat cushion and back heater elements through individual voltage supply circuits. Power is supplied to the passenger seat cushion and back heater elements through a common voltage supply circuit. All of the driver and passenger seat heater elements are grounded by the driver seat module through individual low side drive control circuits. The heater element control circuits are pulse width modulated to ground by the driver seat module in order to control the seat temperatures by regulating the current flow through the heater elements.
DTC B2435 or B2440
The driver seat module relies on inputs from thermistors installed in the driver and passenger seat backs to control heated seat temperatures. The thermistors are 2-wire sensors supplied with a 5-volt referenced signal circuit and low reference circuit from the driver seat module. Resistance through the thermistors varies with temperature causing the heated seat sensor signal circuit voltage levels to decrease as the seat back temperatures rise.
Install a scan tool.
Start the engine.
Turn the heated seat ON.
With a scan tool, observe the Heated Seat Sensor parameter in the data list for the driver seat module.
Does the scan tool indicate that the heated seat sensor parameter is within the specified range?
0.078-4.94 V
Dec 08, 2016 | GMC Yukon Denali Cars & Trucks
Seat removal on 2009 harley softail deluxe
To install slide the retention nut over the tapered end of a cable tie strap so
that the larger O.D. of the nut rests on cable tie strap eyelet, then from the bottom of the rear fender feed the cable tie strap up through the fender hole, with the tab on the retention nut seated in the notch in the fender hole pull up on the cable tie strap to locate the nut snug up against the underside of the rear fender and then from the side opposite the tab i.e. from the rear of the fender slide the retention washer onto the nut which will lock it in place.
The FXST/FXSTB seat attaches with a single thumbscrew on the seat bracket. When installing a seat insert the tang at the front of the seat into the channel in the frame and install the single rear thumbscrew which Harley- Davidson has a special tool for which I have never even seen, pn HD-47190.
The FXSTC seat attaches with two fasteners through the sissy bar. When installing the seat the tang at the front of the seat is inserted into the channel in the frame and the two rear fasteners go through the and get tightened to 60-80 in-lbs (6.8-9.0Nm).
The FXCW/FXCWC Solo Seat is attached with 2 locating pins that for removal must be removed from their grommets by lifting the rear of the seat, then the seat is pulled to the rear to disengage the tongue from the frame. To install the seat put it on the frame, slide the seat forward until the tongue locks into the bracket, push the seat forward to align the two locating pins with their grommets and then push the seat down to engage the locating pins.
The FXCWC rider Seat is removed by tipping the seat up and towards the fuel tank, the two fasteners are removed and the seat is then taken off the bike. Do the reverse to install the seat and tighten the fasteners to 90-110 in-lbs (10.2-12.4 Nm).
The FXCWC Passenger Seat Support is removed by tipping the rider seat up and towards thefuel tank removing the two screws and washers from one pillion support, removing the pillion support and the rear seat pillion, then removing the remaining pillion support. To install it install one pillion support but do not tighten its fasteners, install the wave washer and bushing on each pillion support, install the pillion and the second pillion support and tighten all of the fasteners to an initial torque of 30-35 ft-lbs (40.7-47.5 Nm), then loosen the fasteners and then final tighten them to 38-42 ft-lbs(51.5-56.9 Nm), check the rider seat operation and then lower the rider seat into position and engage the locating pins into their
grommets.
To remove the FLSTN/FLSTF/FLST/FLSTC seat remove the passenger seat and seat mounting fasteners. When installing the seat insert the tang at the front of the seat into the channel in the frame and install the seat mounting nuts, then install the passenger seat.
To remove the FLSTSB seat remove the screw from the seat hinge at the front of the seat, raise the rear of the seat only slightly during removal or installation because pivoting the rear of the seat up too high can cause the nose of the seat to damage the leather trim panel on the fuel tank., to disengage the springs from the seat spring mounting pins and remove the seat. To install the FLSTB seat align the seat hinge with the mounting bracket on the frame, insert the screw into the seat hinge from the right side of the motorcycle and tighten it to 14-16 ft-lbs (19.0-21.7Nm), align the bushings on the seat springs with the mounting pins and push the rear of the seat down to engage the seat spring mounting pins. The seat position may be adjusted forward or rearward for rider comfort by removing the seat, removing the nut on the seat hinge, removing the bolts from the seat spring support bracket, (the seat hinge and seat spring support bracket must be installed in the same position in either a forward or a rearward configuration for the seat to fit properly on the motorcycle). To position seat forward install the hinge with the front tab in the slot, install the seat spring support bracket with the springs toward the rear of the seat. AND to position the seat rearward install the hinge with the rear tab in the slot and install the seat spring support bracket with the springs toward the front of the seat., THEN install the nut on the seat hinge and tighten it to 20-25 ft-lbs (27.1-33.9 Nm), install the screws for the seat spring support bracket and tighten them to 15-20 ft-lbs (20.3-27.1 Nm) and then install the seat.
May 18, 2014 | 2005 Harley Davidson XL 1200 R Sportster
Take the seat off
  • Open tool box, at rear of seat, with key and unhook or unbolt the seat from inside tool box.
  • Pull lever on right or left side, up under the seat. It can also be at the rear of the seat, right or left side, again up under the seat. Lift seat off up and to the rear. Sometimes it's hooked on both sides with a rod or cable connecting both sides. These can break. Make sure both are unhooking.
  • Same as above only you use a key.
  • Remove the two bolts on either side at the rear of the seat. Pull seat to rear.
  • Nuts or bolts, at the rear and below seat, under the rear fender Remove bolts holding down the rear seat . Remove seat and then remove two bolts, at the rear, holding the front seat on.
  • Unlock lever on side of seat. Seat then pivots on two hinges to open. Can open to the right or left. Might have no lock.
  • Push button on side. Left side, I haven't found a push button on the right side... yet ! Can be locked or unlocked with a key.
  • Pull lever at front of seat, right or left side. Seat lifts up with the hinge at the rear.
  • Pull lever at rear of seat, right or left side. Seat lifts up with hinge at front.
  • Pull lever at front of seat, right or left, and whole seat comes off. Seat has pegs underneath that fit into rubber grommets on the frame.
  • Dec 10, 2013 | Motorcycles
    How can i move a power seat that wont move
    On these case go with the solved problems related to these issue.
    Click the link below and follow the procedure:-----
    1994 Lexus GS300: Power seat will not go back? http://howtobyme.blogspot.in/2012/05/1994-lexus-gs300-power-seat-will-not-go.html
    1997 Toyota Avalon: Power Seat will not Move back? http://whatisbyme.blogspot.in/2012/05/1997-toyota-avalon-power-seat-will-not.html
    1998 Chevrolet Corvette: Power Seat Control Now Working? http://schematicsdiagram.blogspot.in/2012/04/1998-chevrolet-corvette-power-seat.html
    Power seat will not go Forward http://repairhelpcenter.blogspot.com/2012/10/power-seat-will-not-go-forward.html
    Replacing power adjustable bucket seats to both heated and cooled seats?
    http://schematicsdiagram.blogspot.com/2011/12/replacing-power-adjustable-bucket-seats.html
    Volvo Seat Removal with Heated Seats? http://schematicsdiagram.blogspot.in/2012/07/volvo-seat-removal-with-heated-seats.html
    How to Remove Rear seat on Rover 600? http://repairhelpcenter.blogspot.com/2012/01/there-are-3-10mm-bolts-at-back-of-seats.html
    How to remove Seat? http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-seat-on-acura-integra.html
    These will help.
    Thanks.
    Nov 23, 2012 | 1998 GMC Jimmy
    Remove front seat
    SECTION 501-10: Seating 1998 Escort/Tracer Workshop Manual REMOVAL AND INSTALLATION Seat —Front Removal
    NOTE: Driver side seat shown, passenger side seat similar.
    1. Slide the seat to its rearward position.
    1. Remove the front seat track to floor front bolts.
    1. Slide the seat to the forward position.
    1. Remove the front seat track to floor rear bolts.
    1. Disconnect the safety belt warning indicator switch electrical connector.
    1. Remove the front seat.
    Dec 06, 2009 | 1998 Ford Escort
    How do i remove the front seats of a 1998 Pontiac Grand Prix?
    On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
    The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
    A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
    The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
    The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
    Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
    Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
    W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
    Sep 01, 2009 | 1998 Pontiac Grand Prix
    Middel seatbelt will not loosen
    I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
    Rear Seat Backrest —Split Bench Removal
    NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
    1. Remove the 40% rear seat backrest.
      1. Remove the nuts and bolts.
      1. Remove the backrest.
    1. Remove the 60% rear seat backrest.
      1. Remove the nut and bolt.
    Installation
    NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
    1. NOTE: Do not tighten the nut and bolt at this time.
      Install the 60% rear seat backrest.
      1. Install the rear seat backrest.
      1. Install the nut and bolt.
    1. NOTE: Do not tighten the nuts and bolts at this time.
      Install the 40% rear seat backrest.
      1. Install the nuts and bolts.
    60/40% rear seat backrest
    1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
    40% Rear Seat Backrest
    1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
    Jun 11, 2009 | 2005 Ford Escape
    I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
    the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
    The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
    First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
    Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
    Rear -Rear
    6 inches forward of that.
    another two ft to the second row seating position
    full frward against the front seats.
    Pleae rate as fixya if this helps.
    c4253aa.gif Seat —Third Row Bench Removal
    sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
    1. Remove the second row seats. For additional information, refer to Seat—Second Row .
    1. Remove the floor mats.
    1. Lock the seat cushion in the upright position.
      1. Lift the handle to release the cushion.
    1. Move the third row bench seat to the second row position.
      • Lift the seat track release handle.
    1. Remove the two bolt covers.
    1. Remove the two seat track front bolts.
    1. Remove the four seat track rear bolts.
      1. Position the rear seat cushion floor cover aside.
    1. Remove the third row bench seat.
    Mar 02, 2009 | 1997 Mercury Villager
    Shoprider Streamer Sport Power Wheelchair 888WA- Used Power Chair Logo
    21 people viewed this question
    Top Shoprider Health & Beauty Experts
    Robin Hill
    Robin Hill
    Colin Taylor
    wcdoc1953
    wcdoc1953
    Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
