Question about Eclipse CD8445 CD/MP3/WMA Receiver
Cd wont eject , face wont close - Eclipse CD8445 CD/MP3/WMA Receiver
I have a jvc am/fm cd player kds-30 it has no eject button anywhere and i can not figure out how to eject the cd
The eject button is just above the JVC logo on the display panel.
When you press eject and if it displays "NO EJECT", then it is locked. Press and hold CD and Power (ATT) for more than two seconds.
Feb 09, 2012 | JVC AM FM CD DET FACE CAR STEREO
I dont know how to put the cd in
Press the eject button then place the cd in painted side up.
Dec 04, 2011 | Panasonic Home Theater System System
My cd is stuck in my cd player and wont eject in my merc
i had this problem and i just used a normal kitchen knife to lever the cd up or down to get it facing the slot and then eject, it just seems to stick on the fascia, if it wont take a cd in there is probably already a cd stuck in it.
Jan 17, 2011 | 2004 Mercedes-Benz Mercedes Benz E Class
Cd drive has disk in it and wont open
Look closely on the face plate and around the face plate of the CD drive. (better to have good flash light/Torch while doing this). Close to the eject button (Or around that area) there will be a very small hole (pin hole). Switch off your computer if it is powered. Push a needle or a safety pin into this hole. Take care to push it in straight (not angled). If it does not open in the first attempt repeat changing the angle slightly. May take 3 or 4 tries. But you can definitely get it opened.
Jan 27, 2010 | Computers & Internet
CD WONT EJECT PIN HOLE
If it's trying to eject you may need to use a small screwwdriver to lift up on the CD. This works when mine hangs up. If it's not trying to eject at all, then the little motor on the ejecting mechanism may have failed or come off track. I had to replace the original CD player about a year ago because of this. That's why I have the JVC now, and it seems that CD's started hanging up from day one with this radio.
Jul 16, 2008 | JVC KD-G210 CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
Clarion db165
take the face off, and stick a small pin in the reset button.
May 14, 2008 | Clarion (DB165) CD Player
CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Sep 27, 2007 | Kenwood KDC-215S CD Player
Cd ejection
Look for a tiny, recessed Reset button on the front of the unit with the face removed. Press this button with a pen tip; it should spit out the CD and work correctly afterwards. This will also erase your station presets and audio settings.
Mar 13, 2007 | JVC KD-SX770 CD Player
Eclipse CD8445 CD/MP3/WMA Receiver Logo
16 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
