Rti150.bpl not found?
When I try to run spybot
    Prodigy:
    An expert who has answered 500 questions.
  • Computers & ... Expert
  • 510 Answers
Either contact the publishers or re-install the software with the latest version.
Posted on Feb 11, 2014
"rtl150.bpl" file is missing
This file is a part of spybot. If it is missing, you will not be able to easily re-install the program, so I suggest that you re-install spybot, then uninstall and re-install again. Sounds unnecessarily clunky, but should work. Cheers, Don.
Jul 07, 2014 | Computers & Internet
Erro no rtl120.bpl
You have a virus. Use your Antivirus to scan your system, if it don't find the problem, download spybot S&D 162 and run that.
Oct 26, 2013 | Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
How do i get a download fro the application rtl120.bpl. It says i need to install to fix errors?
I have no idea how to download rtl120.bpl. Spybot wants me to delete and redownload Spybot 1.6.2, but that would wipe out the malware in the Recovery files of Spybot 1.6.2, so I'll just continue to delete the error message on boot up.
Jan 20, 2011 | Computers & Internet
Rtl100.bpl what is it.
it sounds like a program was removed and the operating system is trying to run the program when the OS starts up. Are you having any problems with your programs or virus scanner? A virus can disable/remove files or programs. Did you un-install any programs? Did your virus scanner find any malware or virus and remove them? Try all your programs and see if any have trouble starting. Check the windows start-up folder and see what icons are in that folder.
Sep 24, 2009 | Dell Inspiron 1525 Notebook
Rtl100.bpl
If the error is that Rtl100.bpl is not found then you can try the following:
Go to start ,run, and type the following:
iexplore -extoff
And see it that stops the error.
If not, try repairing the system files by typing the following in the Run box:
sfc /scannow
May 15, 2009 | Dell Microsoft Windows XP Home Edition
Sir i have a problem with laptop,its effected from a.exe virus.how do i remove it,please help.i am usin gxp {profesional}
You will have to try a bunch of different software to get rid of this. Let's start you off from the top.
ESET NOD32 Antivirus.
Malwarebytes.
Ad-Aware.
Spybot Search & Destroy. (When installing Spybot, make sure to uncheck TeaTimer.exe. In other words, don't install it!)
AVG Anti-Rootkit Free.
You will need to download each utility. After installing them, restart your computer. After the restart, open up NOD32 Anitvirus and update its security definitions file. After it has been updated, perform an in-depth scan on your entire computer.
After NOD finishes, exit the utility and open Malwarebytes. Update Malwarebytes' security definition files. Afterward run a full scan on your entire computer. After the scan finishes, remove anything found (restart if necessary).
After Malwarebytes finishes, open up Ad-Aware. Update Ad-Aware's security definition files. Afterward run a full scan. If anything is found, remove it and if necessary, restart your computer.
After Ad-Aware finishes, open up Spybot Search & Destroy. Update Spybot's files then exit Spybot. Now open up Spybot again and select the category, "Immunize." After the automatic scan finishes, select, "Immunize" at the top of the aplication. After immunization is complete, exit Spybot. Now open up Spybot, again. After Spybot loads run the scanner (Press, "Check for Problems"). After the scan finishes, remove anything found then restart if necessary.
After Spybot finishes, open up AVG Anti-Rootkit Free. After the application finishes loading, perform an in-depth scan of all hard-drives. If anything is found, remove it then restart your computer.
If the virus remains after following the steps above you will have to get your computer repaired as it only gets trickier from here.
Let me know how it turns out for you. Don't hesitate to let me know if you need any more assistance.
Apr 25, 2009 | Microsoft Windows XP Professional
Updated Spybot Search & Destroy. Right afterwards I tried to change my trial avg virus protgram to theh free avg virus program. The application failed because rtl100.bpl was not found. Now I can't...
ya i did that once to and the only way i could get rid of it was to restore the computer or fix it if your runing vista you can install your restore disk and it wil ask you to restore ,fix,or to restore all try to fix first .....
Jul 14, 2008 | Computers & Internet
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
