Question about HP HEWLETT-PACKARD CX056A Deskjet 3520 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan HEWCX056A HEW CX056A
Hp printer cx056a not printing with new cartridges
Paper feds through printer but not printing text
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
SOURCE: won't print after changing print cartridge, check printer cartridge light comes on!
please install the printer hp 1200 series
Posted on May 02, 2009
dnewcombe1
  • 1564 Answers
SOURCE: My HP LaserJet 3050 will not grab and feed paper
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
Posted on Sep 04, 2009
SOURCE: HP photosmart C4480 printer cartridge incompatible error
Well....I solved the problem......bought a new Canon printer!!
I tried everything...unplugging, cleaning everything that was mentioned above. I was onto HP online support several time, but they were absolutely no help at all...they basically told me that the cartridge must be damaged or ink dried up and to buy a new cartridge to see if the error persisted.....I don't think so!!!
I will never by HP again after having issues with the last two I have had. I love my new Canon printer it is EVERYTHING that HP wasnt.
Posted on Jan 16, 2010
  • 16 Answers
SOURCE: HELP PLEASE
Remove one cartridge and close the access door. If the cartridge light goes off, the bad cartridge has been removed. If the light continues to blink, remove the other cartridge and reinstall the first one. If the light goes off, the cartridge in the printer is the good one.
Posted on May 31, 2010
When print to the printer then printer take the paper and print the paper but when paper out the printer then paper is blank
If the printer accepts the commands from the pc and acts like it is printing, but no ink appears on the page, it probably means that the ink has run out and the cartridges are not supported by the printer, ie, refilled cartridges. If the cartridges are relatively new and are HP cartridges, the problem might be with alignment of the printer, but that is not likely. The most likely is that the cartridges are bad and new ones are needed. In either event it is probably too expensive relative to the cost of a new printer to try to fix this one because if the cartridges are not bad, you risk wasting the money buying new ones when the printer repair is not cost effective. One thing you might check is that the paper path is clear so that when the paper is fed through it does not get held away from the print head. Also check that the paper is following the correct path as it is printing. In any event, these printers are not expensive enough to spend much time trying to repair them.
Apr 19, 2011 | HP DeskJet 810c InkJet Printer
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My print is fuzzy and has a lot of skips in the text. The problem started when I put in "copy" paper and new cartridges from cartridge world at the same time and I cannot tell which might be the problem,...
Some copy papers are extremely thin, and the printing on them will look fuzzy, but if you have skips in the text, this problem is with the cartridges. Look at the heads of the cartridges and see if they are clean. If that doesn't work, i would return the cartridges and try another set. The same thing happened on my HP, I replaced the cartridges and it worked fine!
Feb 12, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
HP Deskjet3845
To remove the jammed sheet of paper :
1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out. CAUTION! The paper may be covered with unfused toner, which can stain garments.
6. If you see no paper jammed under the cartridge, remove paper tray 1. The paper may not have fed all of the way into the printer.
7. Reinstall the paper tray and the toner cartridge.
8. Close the upper front door.
Mar 11, 2009 | HP Deskjet 3845 InkJet Printer
Printer has started to misalign text, moving up past labels
Verify your paper settings match between the printer and PC. If a roller is dirty the paper might feed late.
Jun 17, 2008 | HP LaserJet 2420 Printer
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
Not printing text
with a wet paper clean up the head of the cartridge, and let some tint go to the napkin, or paper :) Resulted for me
Dec 21, 2006 | HP PSC 2410 All-In-One InkJet Printer
HP HEWLETT-PACKARD CX056A Deskjet 3520 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan HEWCX056A HEW CX056A Logo
61 people viewed this question
Seeker5211
Seeker5211
