Question about Fisher and Paykel Washing Machines
Error code 212 - Fisher and Paykel Washing Machines
2 Suggested Answers
tech435
  • 284 Answers
SOURCE: Error code 212
are you faxing from you computer . because this could cause the error
Posted on Sep 22, 2008
How to fix AOL Desktop Error Code 212 ?
try here .http://www.sooperarticles.com/internet-articles/blogging-articles/how-fix-aol-desktop-error-code-212-1583321.html
Jan 18, 2018 | AOL Computers & Internet
Code 212 1995 Volvo 850
If you are using port A2. error 212 is a bad O2 Sensor.
if you are using port A1 error code 212 would be a bad transmission and it would behave quite badly.
Mar 23, 2015 | 1995 Volvo 850
Error code 212
212 Comms Error between Outdoor Unit and HR Box No3. 1. Defective connection in HR unit power supply and transmission connection 2. Wrong setting of the HR unit Rotary switch and Dip switch 3. Defective HR unit PCB
Feb 14, 2015 | Heating & Cooling
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
J8 Error Code
There are a few different part numbers for those cartridges, the chip on them bills differently.
A J8 means although you have a 212 cartridge, it has a chip on it that does not match your machine setup.
A J8 indicates a mismatch in the cartridges and the machine. No you do not have the wrong physical cartridge, it just has a different chip on it.
Nov 08, 2008 | Xerox 212 Laser Printer
What is about Error 212 ?
E212 Lens sensor or motor problem
remove the glass, check to see if sensor is out of place. turn off copier move lens by hand and turn on does lens move, yes motor is most likely O.K.
does it stop at the sensor and give code? yes replace ( or swap sensor) doesa it still do it? No? replace bad sensor
Oct 29, 2008 | Canon NP 6050 Copier
Error 211, 212!!!
Hi Antonyo,
The codes you are getting (211- 212) relate to the boiler tank behind front panel.
210 Temperature probe short circuit Check probe cable (plug contacts)
Replace probe(rinse tank)
Install probe correctly
211 Temperature sensor interruption See 210
212 Actual boiler temperature too high Contactor welded
Incorrect sensor / defective sensor
Check probe / cable (Contact plug II XA5)
Hope this helps ,regards KIT
Jun 06, 2008 | Meiko DV 80.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Error code 212
Verify that the phone line is ANALOG, not DSL
Aug 30, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Washing Machines Logo
21 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
