Question about NINJA 3l Deep Fryer
Deep fryer won't turn on
Won't turn on
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
One leg and plastic corners broke off
Chances are from looking around it won't be too easy to find replacement parts. May be better off making something for it out of a hard wood or something. Doesn't seem they have their own website or parts available.
Oct 19, 2012 | Bravetti EPF1100FS Deep Fryer
Burner won't light
if its electric ignite but gas powered then take the grill cover off find where it sparks and rub it with a pencil eraser.
Oct 10, 2012 | Pitco Frialator 45C Deep Fryer
I change the thermocople but now the burner don't lit
Hi there!
Check if the thermocouple is properly heated by the pilot flame.
Check also if the hi limit has continuity across the terminals.
Regards.
Apr 23, 2012 | Star 30lb Gas Counter Top Deep Fryer 630fd...
Put a new valve in a imperial fryer pilot lights and stays lit but when i turn the t-stat on it shuts off
The reason is the pilot generator will hold the safety magnet but it won't operate the solenoid.
It is old and weak.Ain't putting out enough power to operate the solenoid. Get a new generator
Jul 16, 2011 | Imperial IFS40 Deep Fryer
Imperial IFS-40 fryer. Pilot is lit, but buriners won't come on when the temp dial is turned from off to any degree.
Sounds like your thermostat is bad? We could order you one, however in order to get you a price, I need the serial number also. These are very common fryers,our best seller by far and a good fryer too. But, things happen, and the thermostat is the most common part that is replaced after some time....
Our phone is 888-542-5959, Restaurant Equipment Outlet, Cincinnati, Ohio. We ship parts in 1-2 days, and I can get you a price in a few minutes time, if you call or email me. Thanks, Susan REO
Jul 09, 2011 | Imperial IFS40 Deep Fryer
45C- Flame and pilot went out during operation, Pilot won't relight.
If your pilot is a manual ignition model, make sure that the thermopile is clean (free of soot), it is the cylindrical piece of metal behind the pilot assembly which is heated by the pilot flame, a very small amount of voltage is generated by it to open pilot and main burner valves of gas valve.
Jun 03, 2011 | Pitco Frialator 45C Deep Fryer
NINJA 3l Deep Fryer Logo
97 people viewed this question
Top NINJA Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a NINJA Kitchen Appliances - Other Expert? Answer questions, earn points and help others
