Question about Apple Computers & Internet
Video wont work. It says "Block plug in" - Apple Computers & Internet
    Problem Solver:
  • 16 Answers
You have to update your plugins, if that docent work , try to download a new web browser
e.g google chrome or firefox
Posted on Jun 20, 2014
My 05 chevy just shut down while driving fuel pump is working but truck wont crank just spin over but wont catch. had some problem 4 yrs ago at a red light it die the shop replace a sensor over on the
It could be 101 different things including a dead sensor. Too many possibilities. If you are not an experience mechanic, you need to take to someone honest that is experienced. If it were mine, I'd first hook a scanner to it to see if any trouble codes. If no codes, I check to see if it is getting any fire to the plugs. If the plugs are firing, it is a gas issue. I'd next hook a tester to the injectors to see if they are getting current. If they are, I'd check the fuel pressure with a gauge.
Oct 04, 2014 | GM Carts 02 03 04 05 06 07 08 Chevy...
Block heater plug located
most gas powered cars dont come with a block heater.. you get an aftermarket unit and put it in or on somewhere.usually in the block in place of a freeze plug or you can get a magnetic one that just sticks to the block.. or there is one that hooks into the radiator hoses and works like a coffee perkolator..then if you can.. park the car in a heated garage..when its really cold outside I use a bunwarmer thats 300 watt and I flip it upside down and place it under my engine oilpan..it keeps the engine warmer for easier starting..dangerous if used wrong but it works..its a radiant type heater..has a reflector in behnd the element..this also works.. if you stop the car .. park it with the nose out of the wind..just a few degrees difference sometimes works..and change to a lighter oil in winter..it wont be as thick on startup..like glue..
Dec 08, 2013 | Chevrolet Malibu Cars & Trucks
PC wont power on. Even the light next to where you plug in the power cord won't come on. Tried removing and re-inserting battery. First time it worked but now wont power up at all. HELP
Please find someone with a volt-meter to verify your power block is putting out the correct DC voltage. It appears the battery may be out of power and is not being charged. Generic replacements are available for the power block, just need the information on the block to locate a replacement if it is not performing as it should.
Aug 25, 2011 | HP Pavilion dv6-1030us Notebook
Is there an plug in or outlet for warming the engine block in extreme cold?
It will have one if it has a block heater if it doesn't have a block heater it wont have a plug.
Dec 13, 2010 | 2000 Volkswagen Jetta TDI
My pv-gs180 camcorder wont power up. I have
Remove battery plug it into power (charger block) then do reset.
Oct 12, 2009 | Panasonic PV-GS180 Mini DV Digital...
Xbox wont turn on!!
Check the lights on the power block, if they are green when plugged in then the power block is fine. If the light on the power block is yellow when it is idle. If you get a yellow light then it changes to red, you have a short in the power supply and it needs to be replaced. There are 2 different types of power blocks, 1 is for the older models which is a 175W unit and the newer ones are 203W. Look on the bottom of your power block for a label, the ratings are imprinted on it and the wattage is about 3 lines down from the top.
Aug 06, 2009 | Microsoft Xbox 360 Console
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
Feb 06, 2009 | Microsoft Xbox 360 Console
Engine block heater not working/truck wont start if cold
Hi bud876 did you get a faulty block heater? if the cord and block heater are new it should work when energized double check for power, as far as glow plugs do they cycle? is the glow plug relay working properly?you would be a lot better going with a circulating heater rather than a block heater,hope this helps good luck
Nov 09, 2008 | 2003 Ford F350 Super Duty DRW SuperCab
I have a xbox 360 microphone when i plug it in i hear people talk but it wont let me talk
my son says to check the parental settings on the xbox. apparently it can block you talking
Aug 02, 2008 | Audio Players & Recorders
Computers & Internet Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
