Question about Panasonic Fuse Part F62308F00Ap
How to replace Panasonic Fuse Part F62308F00Ap
Panasonic Hoover cleaner motor cuts out and fuse blows
Using too much current. check to make sure that the motor is spinning at the correct speed. If there is grease caked on bearings it might be spinning slow, overheating, using too much juice and shutting down.
If motor speed is up to par and condition persists you may have some burnt/shorted windings responsible for the issue - the motor has to be replaced.
Dec 23, 2016 | Hoover Vacuums
Panasonic vacuum cleaner just stopped running
Set the on/off switch to off, now check near the top of the "beater" portion, I think that model has a reset button, you should hear a slight "click" when depressed. Try turning the vacuum back on.
Aug 26, 2014 | Panasonic MC-V5217 Vacuum
How to fix panasonic mc e450
The thermal fuse for the motor is inside the motor on some models or screwed to the motor case on others
Aug 08, 2014 | Hoover Vacuums
Is there a fuse in panasonic model mc cg885 vacume
http://www.panasonic.com/consumer_electronics/vacuum/default.asp
go to the web and see your model and download from read the instruction manual, section troubleshooting.
Some models have thermal fuse.
God bless you
Sep 16, 2012 | Panasonic MCCG885 Bagged Vacuum
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
Suddenly stopped running in the middle of vacuuming a room. Tried another outlet and still no power.
You have to go to the electrical panel that serves your home or apartment and locate the fuse that is blown [ if there are fuses, replace the blown one with a new one of the same amperage] or the circuit breaker which has kicked part way off. With a circuit breaker you have to turn it all the way off and then back on in order to reset it.
Aug 14, 2009 | Panasonic MC-V5481 Upright Vacuum
The 10 amp thermal fuse on my Panasonic MC-E468 vacuum cleaner has blown. Unfortunately the red ink has worn off exactly where the temperature rating is printed so even with a magnifying glass cannot make...
It appears the fuse is not available separately. Standard retail price for the complete unit is £9.00 including VAT. We can supply at that price plus postage and packing at cost, which would probably be no more than £2.50.  If this is of interest to you, please reply with an email address where I can contact you direct.
Apr 14, 2009 | Vacuums
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Panasonic Fuse Part F62308F00Ap Logo
81 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
