Question about McCulloch Electrical Supplies
Gas shut off leaks
Need part number for replacement shut off
I have a Suffolk punch 14 s with a Tecumseh engine model number AQ148 when I turn off the throttle petrol leaks out of the air filter please could you tell me how to fix the problem. Many thanks Neil
If engine runs fine and thats only problem the quick is a fuel shut off valve install and turn gas off before shut engine off or I think it is fuel float in carburetor that will need to be set or replaced.
Jun 16, 2015 | Tecumseh Garden
Why does my carburator leak gas?
You probably need to replace it.... :-(
May 13, 2014 | 1981 Yamaha XS 400
How to shut off until plumber replace the leaking pipe
Find the cold water supply pipe to the tank. Most are labeled, but if unsure - turn on the closest hot water faucet and feel the temperature of the pipes connected to the water tank. Follow the coldest pipe back (moving away from the tank) until you reach the first shut off valve on that pipe and shut it off completely.
No more cold water will fill the tank and cause water to spray / leak from the pipe.
There is no need to shut off the gas really, as it is controlled by the temperature sensor on the tank - but if you insist, you should find either a flexible pipe - or a black iron pipe that enters a controller. Most have a dial marked "OFF" "ON" & "PILOT". Simply twist the dial from ON to OFF and the gas will be shut off.
May 16, 2013 | Water Heaters
Gas leak from carburetor into bottom of air intake elbow. Filled empty gas tank and within seconds after opening the shutoff valve under tank, gas started to drip from bottom of intake elbow. Shut off the...
It sounds like the needle valve in the carburetor is not seating properly to shut off the fuel. A badly worn needle or dirt/debris in the needle seat area can cause this. Disassembly of the carb and a good cleaning will be required.
Sep 04, 2011 | Garden
Leaking gas through air filter
If the GCV engine is tilted with the carb. down, it will leak gas. If it is leaking gas setting level, this indicates the float/needle is not shutting the gas off properly. Would need to disassemble carb. and check the float and probably replace the inlet needle. The float hinge may be "varnished" and not allowing the float to "move" and shut off the fuel coming into the carburetor. Hope this helps in some way.
Mar 02, 2011 | Husqvarna 21" Lawn Mower with Honda GCV160...
I have an Ariens st524 model number 932020 that I recently acquired that has a leaky carberator and the gas shutoff doesn't shut completely so all of the gas just leaks out while the machine is in storage....
I think the leaking gas at your carb is caused by the float or inlet needle that controls the proper amount of gas going in the carb. If you remove the float bowl from the carb to get at the float, remove the float and check to see if there is gas inside inside the float by shaking it. The float is very light as you can see, so a little bit of gas inside makes it not control the gas level at the proper level. You can also wipe the float dry, then move it around and if there is gas in it you will see a wet spot. If leaking install new one. It could also be the inlet needle sticking and allowing too much gas to get in the bowl. When gas leaks out of the carb that way that is usualy the problem. I hope this helps you out a little. Best regards and good luck. I will gladly answer any questions.
Dec 25, 2010 | Garden
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
Need to know where the termostat goes in the waterheter?
The thermostat probe on most residential water heaters is part of the gas valve. The thermostat is a non replaceable part of the gas vale and if your t-stat is bad you will need to replace the gas valve also.
This is generally not a very hard job just start off by shutting gas supply valve to off position.Disconnect main gas line to burner,line to pilot light, and thermocouple from gas valve. Remove pipe fitting from gas valve and use large pipe wrench to loosen gas valve.
Before you loosen gas valve you will need to shut water supply off and drain water from tank.MOST WATER HEATER GAS VALVES ARE PRETTY STANDARD ITEMS AVAILABLE AT MOST HARDWARE STORES. Just make sure you purchase valve for the type of fuel you have,such as l.p. or natural gas.Remove gas valve by turning counterclockwise. Use teflon tape or pipe joint compound on all threaded connections for reassembly. Hook up gas line,burner supply line,pilot and thermocouple lines. Refill tank and check and check for leaks. Light pilot and turn gas control to on. Set to desired heat setting . Also check all gas fitting for leaks. Good luck. Thanks
Dec 17, 2010 | Water Heaters
Gas company said faulty safety pilot
If all are leaking gas when it is off, the range probably needs to be replaced. The shutoff valves are not holding. I would say it is pretty unusual for this to happen.
Nov 14, 2017 | Kenmore 75503 Stainless Steel Dual Fuel...
Electrical Supplies Logo
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
