Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced lamp, still no picture, but have sound
Hi! I have just replaced the lamp in my DLP Mitsu for the 1st time. Still I have no picture, but I do have sound. I called the 1 800 number in my owners manual and the tech stated the female and male ends that connect in the housing are very sensitive and may have broke (female end). I'm really confused now. WHat is wrong with my DLP? it is only 2 yrs old. Has new bulb and still I have no picture.
  • 39 Answers
HEY SAM SOUNDS LIKE THE LAMP IS NOT THE ONLY ISSUE,IT COULD BE YOU'RE 5 VOLTSUPPLY IS LOW THE ONLY WAY TO BE SURE IS TO REMOVE THE MANY SCREWS HOLDING THE BACK ON AND ALSO REMOVE THE METAL SHEET TO GET ACCESS TO THE PLUGS ON THE LITE ENGINE AND USE A VOLTMETER TO TEST FOR 5 VOLTS. IF YOU FIND IT IS IN FACT LOW YOU'LL NEED TO REPLACE THE 6 CAPACITORS THAT YOU WILL FIND HAVE AGED (THEY LOOK BUBBLED) THAT ARE ON THE POWER BD. GOOD LUCK. JOE TV
Posted on Nov 12, 2007
Replaced DLP lamp on Samsung HLS5687WX, no picture and in a series of 3 lights on front, first one red others green?
That looks like an error code to me. The manual *should* tell you what that means. this site:
http://www.samsung.com/us/support/owners/product/HL-S5687W
has a manual if you don't have it.
Oct 18, 2014 | Samsung Televison & Video
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Jan 07, 2011 | Mitsubishi Televison & Video
I have a 2005 52 inch Mitsu turn it on and it goes to red light
di you replace the power for the lamp in your manul it will show you the lite set for your tv it it will give you i ideal what wrong. i see so with bad power supply or
the balstor go bad to i chang lamp bastor frist. when
the lamp go bad it will show you it the lamp in front of dlp. i hope this help you out.
Dec 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Just replaced mitsu dlp lamp 52525 orange lamp light is on no picture no light
hello make sure the lamp is fitted securely and the lamp cover is fitted securely the it should go to stand by good luck
shaun
Nov 08, 2009 | Televison & Video
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No Picture no sound
The color wheel will make a high pitched sound or even a clicking sound if it is bad. Also the ballast will make a clicking sound also if it is not seated to the lamp properly or if the ballast need replaced.
Mar 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
