Question about Rockwell Speed Block Sander Model 330
Need rockwell sander 330C parts, #3 (brush 115V)
Where do i find a dust bag for a rockwell belt sander model rc4355k
If you have the instruction book there could be an exploded diagram and parts list and instructions where to buy spare parts.
You could ask the retailer where it was bought.
You could try the manufacturer's website.
Failing those options there are lots of websites providing a spare parts service for power tools. Just google spare parts for your model of power tool...
Oct 24, 2016 | Sander Tools & Hardware - Others
I would like a pdf copy of the manual for a Rockwell 361 belt sander?
this covers the 361
some one loaded the instuction booklet side ways
page 6 is the belt fitting
14 pages
http://www.manualguru.com/rockwell-sonicrafter/361c/users-manual/page-4
Apr 29, 2016 | Tools & Hardware - Others
I need a parts list for Rockwell Jawhorse rk9002
Unable to find a repair parts list, and the manual does not provide much help. The manual does list a support number that you may wish to contact, especially if it is still in the 5 year warranty period. Rockwell Helpline 866-514-ROCK(7625)
May 26, 2015 | Rockwell RK9002 JawHorse Sheetmaster hold...
Rockwell 361 belt sander wont run i have power to switch switch good bad brushes?
Brushes wear out often. Unscrew the brush caps and see if they are worn really low or if the springs are broken. If there is any burning on them, then replace them. Also those brushes sometimes stick in the brush holders because of the amount of dust. When you remove the brush caps, blow out all the dust you can.
The wires that go to the brush holders have springs that wrap around the inside of the brush holder (see picture). Check and see if those springs are broken or if those wires are not connected. Sometimes the fields go out in those but it's not too common. Almost never is it the armature (unless a bearing causes it but that's a mechanical failure, not an electrical issue).
Apr 13, 2012 | Tools & Hardware - Others
Have a porter cable 352vs 3"x21" belt sander. was using it and blue sparks started occuring in the rotor and brush assembly. kept using as I needed to try and finish my project. No longer...
this tool has various type numbers but I checked on the type 5-6 and came up with the same number. the brush number I found is NO30461 and they run from around 3.50 to 4.00 each. If you have removed the brushes if the spring is burnt/collapsed it could have been from a loose brush cap or worse an armature problem. Before I sent it out for repair I would look at the brushes, UNPLUG tool first and remove them after removing look into the brush holder and see if the commutator (part of armature you can see) and see if it is discolored or other obvious imperfections. You can buy replacement brushes online from "ereplacementparts.com" or direct from "dewaltservicenet.com". Let me know if you need more assistance before voting and thank you.
Feb 24, 2011 | Porter Cable 352VS Factory Reconditioned...
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
After replacing the brushes in my old Rockwell belt sander there is excessive arcing between the brushes and the oommutator and the unit doesn't come up to full speed.
Did you dress the brushes to the contour of the commutator?
You wrap the commutator with fine sandpaper and rotate under the brushes till the curve conforms.
If this does not reduce the arcing, then you may have an armature with a bad winding.
Sep 30, 2009 | Bosch Tools & Hardware - Others
Burt out sander.
I would start with the carbon brushes they are easy to replace and you should be able to pick them up at any lowes or home depot
Oct 05, 2008 | Porter Cable 3" x 21" Electronic Variable...
Rockwell Speed Block Sander Model 330 Logo
Top Rockwell Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Rockwell Tool and Hardware - Other Expert? Answer questions, earn points and help others
