Question about Vehicle Parts & Accessories
I need a diagram for an alarm system
03 hyundai sonata
  • 121 Answers
You can visit here:http://www.xcardiag.com/search/?q=diagram, may be it can help you.
Posted on Feb 10, 2014
Testimonial: "Thanks Dwaine."
HOW PROGRAM THE KEY LESS ENTRY FOR SONATA 2012
  1. Cars
  2. Car Maintenance
  3. General Car Maintenance
  4. How to Program Keyless Entry Remotes in a Hyundai Sonata
How to Program Keyless Entry Remotes in a Hyundai Sonata By Christian Killian, eHow Contributor
20Found This Helpful The keyless entry system in your Hyundai Sonata is part of the factory alarm system. If you have to replace a lost or damaged remote, reprogramming will be necessary. The remote is important because not only does it lock and unlock the doors, it also arms and disarms that factory alarm when you open or close your car doors. New remotes are available from any Hyundai dealer. While they will program it for you, you can do it yourself and save a programming fee.
How to Program Keyless Entry Remotes in a Hyundai Sonata(Kleophaus Livingston/Demand Media)
Other People Are Reading
Step 1: Locate the fuse panel under the dash on the driver's side of the car. Just below it is the control module for the factory alarm system. Open the cover on the alarm system control module and locate the memory switch inside.
(Kleophaus Livingston/Demand Media) Step 2: Verify that the switch is in the "Off" position; if it is not, switch it to the "Off" position. This is important for the system to understand what you want it to do when you move to the programming mode.
(Kleophaus Livingston/Demand Media) Sponsored Links
Step 3: Insert the key into the ignition of your Sonata and turn the key to the "On" position. Wait for 60 seconds, then move the memory switch inside the control module to "Set."
(Kleophaus Livingston/Demand Media) Step 4: Depress and hold the "Lock" button on your remote for one full minute. This allows the remote and the control module to communicate and sync. Release the "Lock" button and turn the memory switch in the control module back to the "Off" position.
(Kleophaus Livingston/Demand Media) Step 5: Turn the ignition switch to the "Off" position and test the remote by pressing the "Lock" or "Unlock" button, verifying that the doors do lock or unlock.
Read more : http://www.ehow.com/how_6362326_program-entry-remotes-hyundai-sonata.html
Mar 29, 2015 | Hyundai Sonata Cars & Trucks
Will the alarm system on an 03 Hyundai sonata prevent the car from starting?
yes it absolutely can unhook your battery for about 10-15 minutes let her get back up if it still doesn't start you'll have to take it to the dealer they can reprogram it for you
Feb 08, 2014 | Cars & Trucks
I have a 2003 hyundai sonata and i dont have the remote for the stock alarm. My alarm keeps going off and my car wont start. I bought a new battery and even tried the key in the door still no luck.....
The 2003 Sonata is equipped with a 'starter KILL' burglar alarm system with disables the starting system (using a N/C 'contacts' configuration instead of a N/O contacts configuration). N/C=Normally closed, and N/O=Normally open contacts. When the alarm goes off with a MY Sonata, the only way to DISARM it is with the key fob (remote) originally programmed for it (unless you purchase a new remote & have it programmed for the vehicle at an authorized Hyundai Service Department). NOTE: So long as the keyless entry & burglar alarm system is functioning/operating normally, the alarm will keep going off and the STARTER KILL function will still prevent you from starting the vehicle. One option is left without purchasing a new remote and having it programmed.
1. When the alarm goes off, get into the vehicle and insert the ignition key into the ignition.
2. Turn the key to the 'RUN' position (NOT the ACC position) and wait for the alarm to STOP (usually about 3 to 5 minutes).
3. The engine should then start using the ignition key.
If this procedure doesn't work, the problem will need further diagnosis by a qualified/certified Hyundai Service Technician.
Hope this helps
Aug 27, 2011 | 2003 Hyundai Sonata
2003 hyundai sonata wiring diagram
i have doubt about, how to test the Igniter of Huyndai sonata2003 model. the car doesn't start and i am in a way that i want to fix the problem by myself
Oct 09, 2010 | Hyundai Motor 2003 Sonata
How to shut the alarm on 2005 Hyundai sonata
no valet switch,you will have to replace batteries/keypad to make it work and you CANNOT bypass the system......otherwise whats the point in fitting it??
Jun 26, 2010 | 2005 Hyundai Sonata
Need a wiring diagram for Hyundai Sonat 2002
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 22, 2009 | Hyundai Motor 2002 Sonata
Alarm module fried 2002 Hyundai Sonata
Why did you fry the Alarm System?... Everything you described is controlled by the ETACS module.
91b2a46.jpg adf7aba.jpg fb8f850.jpg Replace the module
Jun 05, 2009 | Hyundai Motor 2002 Sonata
Hyundai sonata 2002 remote
There is a special (proprietary) programming electronics 'black box' for the keyless entry system on all Hyundai vehicles for programming the remotes. This programming is stored in either the BCM (body control module) or the ETACS module (Electronic Time and Control System).
May 22, 2009 | Hyundai Motor 2002 Sonata
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
