Question about Rimage Perfect Image Prism Thermal Printer
Light areas a line down the center
  • 35 Answers
Most likely you have a bad print head? But is also could just be a dirty printhead in need of cleanning. Run this test patern after cleanning the printhead.
John Norman
Max Optical llc.
www.maxoptical.com
Posted on Jun 16, 2014
Epson stylus sx115
Hi, there is a possibility that the ink cartridges that you installed are not recognized properly. As a solution for that, try reseating the affected cartridges. You may also ask your vendor if they can replace the cartridges. Upon trying a different cartridges and issue persists, please contact Epson to process the warranty for your printer or ask a nearest service center in your area.
Nov 16, 2011 | Epson Office Equipment & Supplies
Have a light stripe down center of copy, even after installing new toner cartridge? No Error message.
The most common problems are scratches or lines around the drum. These lines will transfer to the image. If the complaint is a solid or partial line on the image, inspect the drum for a matching set of lines. Replace the toner cartridge if the drum appears damaged or if you suspect the drum to be the cause of the image problem. If you replace the toner cartridge and the lines remain, then there's a good chance that the problem is with the drum.
The other part of the image subsystem which could cause this is the fuser. Scratches or damaged areas of the fuser can result in missing or smudged areas on the printout. Remove the fuser, and examine it closely for damage or deterioration. You can contact your printer manufacturer for a replacement fuser if necessary.
I hope this helps and thanks for using Fixya!
Aug 08, 2011 | Dell Dimension 8400 PC Desktop
Can I adjust my headlights down a bit? I keep getting people flashing at me at night. I checked it out and it looks like I am driving with high beams on.
Thank you for using Fixya.
Here's the procedure on how to adjust the headlight of your tacoma.
•1
Find an appropriate area to align your lights. The ground should be almost perfectly, if not perfectly level. There should be a flat vertical wall against which you can shine your lights and clearly see the boundaries of the beams. There must also be enough room for you to park the Tacoma 25 feet back from this wall.
•2
Prepare the vehicle for normal weight and height conditions. Take everything out of the Tacoma except for the items that stay in the vehicle at all times. Fill the gas tank and make sure the engine oil level is full. Fill all of the tires to the PSI you usually use. Finally, make sure there is someone sitting in the driver's seat during the testing and adjusting process.
•3
When it is dark enough to see the headlight beams, park the Tacoma on level ground, 25 feet back from the wall, facing the wall head-on. Leave the engine running and prop open the hood.
•4
Look at the backs of both headlight assemblies. Near the top center corner of each headlight, you'll find a small round cap. Remove these caps to expose 8mm screws. These screws control the horizontal alignment of the headlights.
•5
Look at the backs of the headlights again, checking the bottom outside corners of the headlights. You'll see identical 8mm screws sticking out. These screws control the vertical alignment of the headlights.
•6
Turn on the headlights and shine the beams against the wall.
•7
Use a measuring tape to measure the distance between the ground and the center horizontal line in the plastic lenses of the headlights.
•8
Go to the wall and measure the distance between the ground and the center horizontal line's reflection in the beams of light. If the line on either side is higher on the wall than it is on the Tacoma, the light on that side must be adjusted to point down. If the line is lower on the wall on either side, the light on that side must be adjusted to point up.
•9
Use a 8mm socket wrench to adjust the vertical alignment screws on the headlights, measuring the horizontal lines on the wall as necessary, until the center lines of both beams are exactly as high as they are on the Tacoma.
•10
Use a measuring tape to measure the distance between the two vertical lines in the center of each headlight lens.
•11
Go to the wall and measure the distance between the two vertical center lines' reflections in the beams of light. If they are father apart than they are on the Tacoma, the headlights need to be adjusted toward the center of the vehicle. If they are too close together, the headlights need to be adjusted toward the outside corners of the vehicle.
•12
Use the 8mm socket wrench to adjust the horizontal alignment screws on both headlights, measuring the vertical lines on the wall as needed, until the distance between the lines on the wall is equal to the distance between the lines on the lenses.
•13
Replace the caps on the top headlight adjustment screws and close the hood.
All the best!
Nov 11, 2010 | 2002 Toyota Tacoma
How do you adjust headlights on a 1993 chevy C1500
if you look at the light, there is an adjustment screw at the top of the light that controls the up and down motion , clockwise will raise the beam, and a screw on the side that controls the side to side motion. the best way to center your lights would be to park the vehicle 25 feet away from a verticle wall. be sure to be very square to the wall and on level ground. make a tape line vertically on the wall in very close relation to the center of the vehicle, and another tape line vertically in very close relation to the center of each headlight. now place a tape line horizontally in very close relation to the center of the headlights. start with low beam adjustment. adjust the high intensity zone to 2 inches below the horizontal line and 2 inches to the inside of the vertical line directly in front of the headlight. for high beam adjustment, adjust so that the high intensity zone is centered on the center vertical line and just below the horizontal line. hope this helps
Apr 04, 2010 | 1993 Chevrolet C1500
Trying to adjust head lamp in a 1995 chevy C1500 just had to buy a new lamp assembly
Oct 20, 2009 | 1994 Chevrolet C1500
Water flowing out of center of front overheats
check all water line hoses in that area could be you have a blown head gasket
Oct 07, 2009 | 1992 Toyota Pickup
Line down center
Often this is merely a mark on the scanner glass. When using the automatic document feeder the light/sensor will stay in one spot and motors will feed it. Make sure to clean the glass in this part usually left of the large glass area is a smaller strip see if there is a mark on the glass there.
Jun 11, 2009 | Xerox DocuMate 510 Document Scanner
Sharp LC-42D62U Dark area in pix, top to bottom in the middle
This unit should be sent in for service. The problem is a bad power inverter circuit or weak backlight.These problems can only be service in a service center. Go on line to the Sharp website and find the customer service section and search for service centers in you area.If you can not find one them call the customer and tell them about your problem and ask them how you can get service for you television.
Dec 29, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Line down the center from top to bottom, 1/2 inch very light , NOT folded.
hi swan.. i am doing some homework on this i got a similar set today.. will get back to you shortly
Mar 13, 2008 | Televison & Video
Rimage Perfect Image Prism Thermal Printer Logo
48 people viewed this question
Top Rimage Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
