Question about Home
Model FDV350 heat reaches temp and shuts off, fan keeps going
To requiredtemphe fan won't shut off when heat is done t
    Scholar:
  • 27 Answers
Here's a link to the manual http://www.kingsmanind.com/files/file/95/fdv350_38.pdf now if you go to this website http://www.kingsmanind.com/contact and contact Kingsman, ask for technical support, and then see if they can diagnose the issue over the phone. If not then ask them to direct you, or you can look it up on the website, as to a local authorized servicing dealer for Kingsman to take a look at what is going on with your gas stove. I hope this helps.
Posted on Jun 18, 2014
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Would like to know if the rear panel fan of this cpu supposed to run all times
Yes, but the RPM's of the fan will change when the heat sensors reach a pre determined temp. You didn' mention your Make. Model of computer or your OS? Overheating will shut down the machine, this is done to prevent damage to components. You may have a bad fan or sensor, or worse. What is the age of the machine? Try to use SpeedFan: http://www.filehippo.com/download_speedfan/. Not knowing your machine, I'm not sure it will work with your hardware.
Dec 11, 2012 | Computers & Internet
Fan on my hvac split system won't stop running
Hello, sounds like the contactor coil is stuck which keeps sending power to the motor. Change out the contactor.
May 06, 2012 | Heating & Cooling
Qmark muh won't shut off
I believe these models have a thermal switch on or near the heating element that normally runs the fan until the element has cooled. Similar to your home furnace. If the fan never shuts off this switch is likely bad. IF it takes a long time to shut off then it may be out of calibration. In either case they are non repairable parts and have to be replaced. If the heater is in a high spot resulting in a high ambient temperature it may take a while for the fan to shut down.
Dec 20, 2011 | QMark MUH (0521) Compact Heater
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
This goldstar air conditioner model is WG2405RY7 It has an energy saver, but the unit just keeps running and won't shut off, everything else works.
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Jun 29, 2009 | Goldstar M1003R Air Conditioner
I set temp to 74 and stop at 70 and decresing.
The only thing I can think of other than being just old and worn out is that by design it may not be set to run but so much at a time. Has this always done this since you have had it? It may be needing calibration. One thing you can try is to set it at 2 degrees higher than you want it and then it would shut off at the temp you actually want.
Mar 04, 2009 | Hunter Fan Company 7-day programmable...
Home Logo
118 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
