Question about Maytag Washing Machines
MVWC200BW TECH MANUAL
Will not agitate
MAYTAG MVWC200BW UNBALANCE WHEN SPINS
There is probably a balance mechanism that is broken or malfunctioning. Call for service.
Feb 28, 2016 | Maytag Washing Machines
Whirlpool Duet GHW9100LW wont spin. Drains fine, but no spin.
see this causes and fix it. God bless you
Door Switch
This can cause the washer to agitate but not go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Need to remove the agitator asm on a hotpoint model VBXR1090B2CC
make sure washer is empty no water no clothes ... this one is not funn even for a technician sometimes dosent like to pull off.... grab bottom of agitator with either your hands and pull upward at very bottom base be carefull not to pull so hard that you slam the agitator top into your chest ... i have taken my belt in some stubborn situations slidding under agitator and pulling upward with my belt to get more thrusting upward action the also make an inflatable innertube tech tool that u put under the agitator and inflate to pop agitator off
Jan 24, 2011 | Washing Machines
Maytag mav 3905 3 years old will not spin water Agitator works fine, but will not spin out water when done. Can it possibly be the transmission? Had 1 tech out today that said yes,another tech(where I...
That sounds more like the clutch assembly. The clutch may be worn. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it.
Dec 01, 2010 | Washing Machines
I was told that modles 95 and newer aggitators can not be removed unless a GE tech does it, is this true
Number 310 holds the agitator. You grab the agitator by the neck and yank it out OT get a belt and slip it under the agitator and use a broom handle for leveredge and twist it around till the agitator pops off9d873a6.jpg
Sep 20, 2010 | GE WJSR2070B Top Load Washer
Weak agitation
hello mam
your machine will have this noise if the floor level is not good and if bearing is worn out so please call the tech and make him to check this.
Aug 30, 2009 | General Electric WHDSR316G Top Load Washer
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
Aug 23, 2009 | Washing Machines
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Wont spin or pump out
these wahers are problematic and expensive to repair. remove whirpool emblem on front and remove 1/4 screw pull top foward and up look inside of front panel and you'll see tech manual
Dec 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
