Question about Cell Phones
Search network then show Emergency
My phone is GFIVE L228 model when i insert any sim card and on phone show searching and always show Emergency. now what can i do for solve this problem
Sunny1985
  • 70 Answers
SOURCE: I bought My L6 phone unlocked. Emergency Calls only
try this code 19980722 OK, ur phone will unlock
Posted on Jan 13, 2008
Bajanguru
  • 7752 Answers
SOURCE: INSERT SIM CARD
take the phone to a mobile service center and have them check the sim holder in the phone
Posted on Dec 26, 2008
SOURCE: No Service!
it is the normal phenominene of samsung mobile to leave signels so on that time u need to restart your mobile or search it mannualy and select the network. this is the only solution of this no other service center can repair it so this is only one way to solve your problem.
Posted on May 25, 2009
entchana
  • 79 Answers
SOURCE: Insert sim card issue
just insert another sim card and check whether that sim card is working. also put your sim card in to another phone and check whether it is working.
Posted on Jul 27, 2009
SOURCE: China Mobile of modal i9+++ of sciphone make is
For I9 support visit to following website: http://www.i9forum.co.uk/. You will have to register to access the site. For your sim card turn it over. It should face up in the bottom bracket and down if you are inserting it into the top bracket. I hope this helps.
Posted on Jan 05, 2010
How do get my phone off of emergency call
This is a normal behavior when a phone does not have a valid/working SIM card. Without a valid/working SIM card or even without a SIM card, the phone can still be used for emergency call.
I hope it helps.
Dec 15, 2014 | Samsung Cell Phones
Vodafone sim
firstly check up with other operator......i.e. airtel etc. ....if network appears with other operator sim inserted, then it is hardware problem.....to confirm this.....insert voda sim....switch on the phone ...then go to menu>settings>phone settings>network selection>and select manual.....now your phone will start searching network......and network list (so called service provider list (or SP list))will appear.....on the top it should be Vodafone........if Vodafone appears then select it....it done......if Vodafone does not appear then its hardware problem.... solution depends on phone model....pl. mention it....older phones develop this this fault when a IC called PFO/PF/PA/or Duplexer develops fault........later phones have a IC called FEM ic in place of duplexer. in latest models its network ic.....this has to be replaced......some new phones have no solution for this
May 02, 2014 | Nokia Cell Phones
Samsung wave s8500 network problem it always shows search sign where it should show the networks network comes only on terrece - can even make calls that time it detects sim always - no problem in that...
I think your phone still locked for canada network, you need to unlock it before you can use that in India. You will need samsung wave s8500 unlock code for your canada network sim to unlock your phone and you can get that code from your network provider or you can buy from third party sites. After you get samsung unlock code, insert that code in your phone then you can use your India sim card. Good luck and have a try!
Jun 12, 2011 | Samsung Wave S8500 Smartphone
My motorola ZN5 PHone showing Emergency call only- what can i do now kinldy help me...
This happens when no sim-card is inserted or your carrier's network is not available. Try to check the sim-card contacts or put it into another phone and see whether it works there. If the sim-card is defective you generally can exchange it for free in the nearest office of your wireless-carrier.
When the phone says "emergency calls only" it means that the phone has found a network, but it can not register in it due to the problems described above. For emergency calls network registration is not required, it is made for so you could call 911 even without any sim-card installed.
Feb 25, 2011 | Motorola Mobility MOTOZINE ZN5 Cell Phone
I have full signal but my phone is only allowing emergency calls how can i fix this?
Most Samsung Mobile show signal tower even if there's no network accessible. I am not very sure about this model, but you can find out, install an expired sim card and check if the network tower is showing or not, or you can just power it on without sim card and check the status of the network tower.
If you suspect the Phone, then first try your sim card on another handset/mobile and make a call using the sim card. In case it's working, then the problem is with your phone, could be settings or could be hardware or software related issue.
Reset your phone settings to it's factory default by going to the "Restore Factory" or "Master Reset" and make the changes. Try searching the Network Manually and do check the network settings very carefully. With many Samsung mobiles, there's an option that allows us to select the Network Band, so verify that there's no band selection problem. You can make the changes after you go to the Network Settings. The simplest method is to Reset the Settings to it's Factory Default.
Good luck.
Thanks for using FixYa.
Aug 22, 2010 | Samsung U900 Soul Cellular Phone
How to detect the sim card i put?
I guess your phone has not been unlocked yet. Unlocked phones do not have any specific carrier software and work with all GSM carriers. These include T-Mobile, Cingular and AAAA . Multi-band unlocked phones also will work with carriers in other countries.So I guess you need to unlock your phone so that u can enjoy in your country.
Sep 22, 2009 | Dual Electronics CECT P168 Cellular Phone
Emergency calls only
hello sir,
this emergency calls only is seen only when ur SIM is not activated or ur cell phone dosent catches the signal. Well it shows the signal full but thats the FAKE signal.
If ur SIM is activated try the MOBILE NETWORKS in the SETTINGS option  >  Connectivity
U will search for new networks and u will find ur NETWORK Operator
If ur SIM is invalid u wil continue receving the same message  "emergency calls only"
Jul 31, 2008 | Motorola Mobility L6 Cellular Phone
MOTOROLA A1200...NEW...SAYS "EMERGENCY ONLY"
1- select your network manual in your handset
2-try another sim card ,so that your either there is problem in your sim card
Oct 18, 2007 | Motorola Mobility MING A1200
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
