Question about Onkyo DV-CP500 Multi-disc DVD Player
Won't turn on from stand by mode
Unit won't open and there is no letters displayed it also won't turn disc table all that happens after pushing on is the standby light blinks
SOURCE: Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Posted on Nov 25, 2008
Gurudristi
  • 98 Answers
SOURCE: The receiver goes on standby mode when volume is high
Your receiver is basically going into protect mode.
The SR 605 contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
Please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem. If you still can’t resolve the issue yourself, try resetting
the AV receiver/AV amplifier before going on to opening the Receiver.
To reset the Receiver to its factory defaults, turn it on and, while holding the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the Receiver will enter Standby mode. (note that resetting your receiver will delete your custom settings as well as your radio presets).
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Posted on Mar 13, 2009
ginko
  • 19396 Answers
SOURCE: My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Posted on Apr 27, 2009
SOURCE: When I push the stand-by/on button - stand-by blinking
WHEN I PUSH THE STAND BY BUTTON THE UNIT GETS ON AND IMMEDEYETLY GETS OFF(YAMAHA RXV-995 IF IUSE 500VA STABULISER THAT PROBLEM NOT COMING PLEASE SOLVE IT
Posted on Sep 10, 2009
  • 4234 Answers
SOURCE: receiver keeps turning on and off also the standby mode blinks
The receiver is going into "protect" mode. This means that a problem has been detected and the unit shut down to prevent further damage. Without seeing the unit and taking some internal measurements, it is difficult to provide a complete solution. Typically, the output transistors fail which can cause this. There are other possibilities too. I would suggest that you get a detailed repair estimate from a local shop. With that information, we may be able to walk you through the actual repair.
Dan
Posted on Oct 15, 2009
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
Crosley CR247 never used, sat for almost year, display :"OPEN"
seems you need to go to the spesific mode, fono, or radio mode.
Sep 04, 2009 | Crosley CR247 Shelf System
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Need the code to unlock regions on LG V9120W
1)turn on power
2)draw tray open
3)push 0 button 3 times
4)press 0 (region code)
5)press pause
OR
1. Turn Player on with no disc inside
2. Set the Unit to DVD mode (Not VHS)
3. Turn Player OFF
4. Turn Player on with no disc inside
5. Press pause on the remote control
6. Then key in 3 1 4 1 5 9
[CODE -- will then be displayed on the player display]
7. Key in desired Region number
[0 for Auto Multi Region, or manually select 1 to 6]
8. Then Press Pause again
9. Turn off player and wait 5 seconds, then back on again.
Sep 13, 2008 | Televison & Video
How to play music cd's
Stop video playback first, then press CD MODE then press PLAY.
Dec 16, 2007 | Pioneer DV-C36 DVD Player
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
Onkyo DV-CP500 Multi-disc DVD Player Logo
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
