Question about Rockwell Speed Block Sander Model 330
Rocwell model 330C finishing sander
When switch is turn ON , power is very slow , almost no energy
My sander doesn't run at full speed - it's slow. I've changed the carbon brushes but this hasn't helped.
if it sparks a lot at the brushes , then there is an armature or winding fault
sanders are cheap so junk it and upgrade
Feb 25, 2016 | Makita BO4900V Half Sheet Finishing Sander
Fix sander
You likely have something bound up or a bad bearing. Take the belt off and turn things by hand to verify they work smoothly
Apr 16, 2014 | Jet 414551 J-4200A Industrial Disc Belt...
It was working just fine. i turned it off, then
Check the switch for continuity. Check the brushes.
There may be a thermal fuse and some of those are one-shot that have to be replaced. They are usually embedded alongside the windings.
Switches sometimes get dust in them and don't contact inpsite of MOVING.
Jun 19, 2010 | Makita 1/4 Sheet Finishing Sander with...
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Need to change felt pad on Makita finishing sander model #BO4552
go to Makitausa.com and type in your model number and you can download a schematic for the tool. Let me know if you can't find it or need more help
Aug 08, 2009 | Makita BO4552KR Reconditioned 1/4 Sheet...
Sander will operate only at a very low level of power.
It is either a bearing or bearings that are failing and causing the sander to slow down or the variable speed switch is failing.
Mar 17, 2009 | Tools & Hardware - Others
Air Sander Question
When you are finishing the surface of wood, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
Aug 27, 2008 | Taylor Pneumatic: Orbital Sanders:...
Speed Control Question
Aug 27, 2008 | Coleman Powermate 024 0091CT High Speed...
How do i refill a finishing sander
Without any more detail about your particular finishing sander, I do not know whether this will help, AND I am no expert, but here goes ...
I inherited a Black and Decker 1/3 sheet sander, with no manual, from my late brother. It is not their newest model -- from the yellow plastic and the general looks and wear, I would say it is from the 1980s or 90s. The sand paper is held by a sort of spring clamp at both the front and back. There is a slot -- perhaps half an inch wide and a quarter inch tall -- in both of these spring clamps. I inserted a wide-bladed screwdriver into the slot, and pryed away from the sanding pad to open the clamp and insert the new 1/3 sheet.
Hope this helps!
Nov 17, 2007 | Black & Decker Compact Power Screwdriver
Rockwell Speed Block Sander Model 330 Logo
48 people viewed this question
Top Rockwell Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Rockwell Tool and Hardware - Other Expert? Answer questions, earn points and help others
