Question about Car Audio & Video
Clarion NX70 going wild
Clarion NX70 has a Nav screen that as it wants takes over any other screen playing a DVD, radio or anything you are trying to keep up. The Nav voice only works sometimes. One Micro SD card appears to have been damaged in it. SD cards don't want to load. Please help me with these issues.
mixmaster
  • 626 Answers
SOURCE: Problems with formating samsung e250 micro sd card
Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
Posted on Sep 12, 2007
DGolfer
  • 79 Answers
SOURCE: micro sd card
Lots of things can go wrong here.. most likely, it is a problem with drivers, which can be resolved using the Device Manager.. but the first thing I would check would be the Disk Manager to see if it is not being assigned a letter that has already been taken..
Start > Run > diskmgmt.msc (ok)
See if it is in the list at the top.. if it is being assigned a letter that has been used already, then right click on the micro and "Change Drive Letter"
Posted on Dec 04, 2007
  • 4 Answers
SOURCE: micro SD card wont work
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
Posted on Jan 03, 2008
SOURCE: Sansa c250 Micro SD card not recocnised
You need to create a folder named MUSIC on the MicroSD card to copy your MP3 files into
Posted on May 10, 2008
MrVanDango
  • 7 Answers
SOURCE: Power Acoustik PTID-4007
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Posted on Aug 07, 2008
Every time i play the cd player it jumps back to the radio
Did you check if the DVD disk you are trying to play is actually playable? Mabe the player can't read the disk so reboots to radio. Also, you should try with another DVD disk
If disk is ok, recheck your original setup options, but I'm quite sure that it's some electronic failure of your device. Simply should not make sense some hidden option to play radio wnen you select the DVD player.
So your final optin probably should de take your device to repair service. Look at your original warranty for nearest authorized repair service, even if warranty has expired.
Oct 18, 2015 | Clarion NX501 Navigation system with DVD...
WHAT IS PROBLEM IF RADIO/CD PLAYS BUT NAV/RADIO SCREEN IS BLACK
its internal circuit problem in radio ,it selector switch is not moving to radio position,
Jun 15, 2014 | 2009 Dodge Journey RT
Clarion NZ500 nothing on screen
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Aug 22, 2017 | Clarion NZ500 Car Video Player
"Clarion" screen will not go away
try and pull the face off and get a pin and depress the reset button
Aug 26, 2009 | Clarion VRX485VD Car DVD Player
Screen is white.. but music plays
no fix, lcd screen is out. call there 1-800 number
Jun 23, 2009 | Clarion VRX485VD Car DVD Player
I have a Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player i can play music on it ,wen i insert a dvd the screen goes black i can hear the dvd playing on my speakers but no picture comes...
there is a safety brake wire that needs to be hooked up. If it was installed professionally, have them explain it to you.There is not supposed to be any video players in view of the driver while in motion. Stop your car and put on the parking brake. If you installed it yourself, you probably didnt hook up the wire. Look inthe install manual for DVD safety wire.
Dec 21, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
