Question about Car Audio & Video
Which wire goes to the power supply side of the parking brake on a 2005 Chevy Avalanche?
I need to find the wire that goes to the power supply side of the parking brake switch to hook up my Pioneer AVH-X3500BHS. I thought I had found it but when I hooked up to it the parking brake idiot light remained illuminated on the dash and the vehicle thought the brake was on when it wasn't.
2005 Chevy Avalanche - The truck is in park, shut off, and the keys out. The brake lights are staying on. What do I need to do to get them to turn off?
There should be a brake light switch under the drivers side mounted on the brake pedal it may have broke or come out of adjustment in any case you could push the switch in by hand and tape it as to not drain your battery until you can get a replacement part for it if indeed it needs to be replaced otherwise it may just need to be adjusted.
Jul 27, 2011 | 2005 Chevrolet Avalanche
How hard is it to replace the splash shields on the rear brakes on a 2005 Avalanche 1500 ? This is the shield that the emergency brakes are bolted to. It looks like you have to pull the axels.
Hi, this is not a terrible job, but you are correct, the axles need to be removed, After this, you remove the park brake shoe, cable, and hardware.Unbolt the shield, swap over park brake stuff, and reassemble. Not extremely har, but is a b it time consuming. Good luck...Coop
Dec 12, 2010 | 2005 Chevrolet Avalanche
I have a 2005 chevy avalanche z71,I need to replace the brake shoes on the parking brake,it has rear discs with the drum inside.Do I have to remove the rear axle to get the new shoes on,they are one piece
no jack up and secure truck remove wheel- brake caliper-mounting bracket and brake disc under drivers side door by frame rail is a 1 into 2 cable with an adjuster this is e-brake cable loosen connection on 1500 models the brake is secured at bottom with a screw and a clip
Jan 22, 2010 | 2005 Chevrolet Avalanche
How do I install an engine block heater on my 2005 chevy avalanche
Cat engine block heaters go in the soft plug on the side of the block. I get those at NAPA auto supply. They have a chart of what position it goes in according to your truck.
Dec 09, 2009 | 2005 Chevrolet Avalanche
My 2005 Chevy Avalanche has no brake lights
See if the turn signals work,and the flashers,the problem,is most likely in one of the flashers,they are stuck,the flasher.
Nov 11, 2009 | 2007 Chevrolet Silverado 1500 2WD
How do i bypass the parking brake switch in order for my video to play
get the lockpick. gen5. about $249. just google for your vehicle
Jul 12, 2008 | 2008 Chevrolet Avalanche
Parking brake
Parking Brake Lead (Yellow/Blue) Connect this lead to the power supply side of the parking brake switch to transmit the parking brake status signals to the IVA-D310.
Mar 04, 2008 | Alpine IVA-D310 Car DVD Player
Parking brake hook up
This wire goes to the "Hot" side of the parking break switch... When the Parking Break is put on, a switch is closed, thus putting an "Earth" on this wire.. Ya can often bypass this by connecting to earth. Sometimes this wire can be "Hot" +12v so B4 doing anything with unit "On" check this wire for any Voltage.
Aug 05, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
11 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
