Question about Canon MultiPASS MP360 All-In-One InkJet Printer
Printer won't print anything either from computer or just to copy something.I have put in new cartridge, cleaned head and still no luck.Help!!!!!!
  • 11 more comments
  • Anonymous Nov 20, 2007
    It's not printing, just quit!
  • ggirlc Jan 19, 2008
    My MP360 churns out blank paper when trying to print or copy but no error message is displayed. Both cartridges have been replaced software reinstalled to no avail
  • Anonymous Feb 12, 2008
    Printer won't print anything. Have replace both the color and black ink cartridges and have software installed. Will not print from computer and will not make copies, keeps printing blank pages.
  • mayamm Mar 16, 2008
    yeah I do have the same problem, But I actually used refilled ink & after sometime printer stopped printing.
  • lory1932 Apr 13, 2008
    Hi I have an MP360 3 in one and it was working then it stopped . I have cleaned it put new cartridges in and it goes through and the paper comes out blank.
    could you please have any suggestions what the problem is thanks
    Theresa
  • jaywalk50 Jun 02, 2008
    Same problem - paper goes through OK, but comes out blank. Have tried sucking ink through print head - which has been a solution for the last year - but now just two brief alarm flashes with fleeting warning 'put in cartridge' and no printing. Any ideas please?
    Rod
  • Anonymous Jun 25, 2008
    Only prints color, not black. Tried all maintenance steps, (including deep cleaning) no change. Replaced cartridge & still no black printing. There are no error messages
  • Anonymous Aug 12, 2008
    I have bought new ink thinking my old one dried up and it did nothing.. My printer will just spit out plain pieces of paper!?!? what to do?
  • Anonymous Sep 09, 2008
    i put new ink (both black and color). It prints out blank paper.
  • ferna5 Sep 09, 2008
    I put new black and color ink. It prints but the paper comes out blank. i downloaded an upgraded driver but problem is still the same.
  • jackiewynne4 Oct 24, 2008
    Yes i have the same problem. changed the ink but it just spits out blank pieces. I am now very frustrated, have done all the tests.
  • Jenny Rosas Nov 24, 2008
    I am trying to print, but my printer is shooting out blank papers, even though I have changed the black ink.
  • yobby1 Jan 15, 2009
    Have tried everything also, will not print from my computer or any documents scanned or photo copied.
My mp360 scanner has lines going through the copy after I scan it. Is there a diy solution.
Posted on Mar 16, 2008
My printer prints blank pages when I want to print files from my computer, but works fine without a computer
If you don't use the printer often (at least once a month) you probably have cartridges drying up on you. If by chance you have an Epson or canon, the print head is inside the printer, so regardless of how many new cartridges you put in there, you will encounter the same problem.
If you are using a generic or third party ink, it may be too dense or of low quality clogging yourprint head.
You can try to run a bunch of print head cleanings. (your manual will tell you how) If by about 8 you are not seeing any improvement start with a new printer. Do a print head cleaning once a month ALWAYS as a preventative measure. This will ensure you get a long life out of your printer, and a top quality print from your cartridges.
Feb 24, 2014 | Canon PIXMA MP240 All-In-One InkJet...
I just put all new ink in my printer and will not print. Unplugged it to re-boot it, still won't work. If i copy something by hand will not print, if i copy something from computer it does not...
be sure that you remove the tape from the cartridges before you insert it in the printer, it has a color pink attach to the tape remove it slowly then insert the cartridge to the printer,
Aug 03, 2011 | Computers & Internet
When trying to print or copy - the paper goes through the printer but there is nothing printed on the paper.
If you haven't printed anything for a long time, probably the cartridge nozzles are clogged and you'll probably need to buy new ones. To check if the nozzles are clogged, remove the cartridge from the printer and genly press the paper napkin on the print head for a few seconds. If the nozzles are clogged, nothing will remain on the napkin, otherwise, there should be some ink on it.
If you find your nozzles clogged, you can try to clean the cartridges (start the cleaning process from the printer driver). If this doesn't help you can try something, but only if you decided to throw the cartridges away, so you have nothing to loose: put the cartridge (with the head downside) into the hot water (but not boiling) and leave it for about ten minutes, then wipe them and put them back to the printer to try printing. Good luck!
Nov 07, 2010 | HP PSC 1215 All-In-One InkJet Printer
I have a MFC290C printer. I put a new black cartridge in and you can't see the printing. It looks very faded. Is there anything I can do to get it to look brighter. Can I clean it or something. I...
Your BROTHER printer appears to have a clogged head OR the configuration settings are set to use the minimum ink.
A clogged head It is caused by lack of use. You need to "clean" the head printer using the installed tools at the computer.
Abut the configuration, check if "Saving mode" is enable on the computer o any settings that may be using little ink on printing.
May 18, 2010 | Office Equipment & Supplies
Black ink cartridge is new but not printing
Was the code of the cartridge you put is correct? if not then replace it.if it is right, then check the nozzles, the printer heads and clean. some printer is equipped with cleaning tools software that might help you.
Jan 20, 2010 | Canon BubbleJet i320 Printer
Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Jul 17, 2009 | Canon PIXMA MP470 All-in-One Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Won't print from 3ebk cartridge
i think there is problum in ur cartridge cas adoptor , clean cartridge circuit plate and put cartridge then try
Jun 05, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
166 people viewed this question
old marine
old marine
