Question about Kicker Ik501 Powered Ikick Iphone Ipod Speaker Dock
Kicker 09ik501 docking amp will only turn on when it feels like it.
I have gone completely through the cards, looking for loose connections, faulty soldering joints, etc., and have made very sure it isn't just a simple adapter plug issue. I have yet to find anything. However, about 2 or 3 hours into testing, it might start working right and continue for 6 months or so before going out again. I'm a diagnositc field service engineer by profession and am well aware that you can't fix it if it ain't broke, so I usually just close it back up and use it after it comes back on. Oh, I'm using the front panel on-off controls as the remote was misplaced sometime ago. I cannot find a schematic for this thing anywhere. Does anyone have any idea why this might be happening?
SOURCE: kicker zx1000 only plays at low volume
your subs are blown
Posted on Sep 16, 2008
SOURCE: Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Posted on Mar 15, 2009
fingaz22
  • 1068 Answers
SOURCE: Kicker KX500.2 amp cuts out for no reason
  • yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Posted on Jan 31, 2010
  • 58 Answers
SOURCE: kicker zx650.4 amp turned off and on
could be a couple of things going wrong. could have overheated and shutdown to protect it. could have hand to many incoming wattage/voltage from your head unit and shutdown. could be that the ohms rating on your speakers is to low or that the speakers could have heated up and bumped the guilds and caused it to shutdown. don't know if you know how ohms works. but here is an exp. if you have and have that is rated at 4 ohm stable and that is the lostes ohm recomened for it. and you have two 4 ohm rated subs. you can run them and run them with no problem as long as you don't bridge them. run them off of the same port on the amp. when bridging them it devides the ohms in half. so 2 4ohms would become 2 ohm. 2 8ohm would become 4 ohm etc. if you are running 4 speakers in pair that are 8 ohm each the total together would be 2ohm. hope this helps. try to duplacate the conditions that was going the other day when it shut down same bass settings same song etc and see if it happens again if so try unhooking one of the speakers and try it again if it don't do it it was overloading it if it was overloading and you know its right ohms etc. send it in sorry this is so long.
Posted on May 01, 2010
thark01
  • 114 Answers
SOURCE: have a kicker zx400.1 hooked
Set the gain to %50 and see what happens, also make sure the amp is well ventilated and not upside down. It has thermal switches for overheating.
Posted on Jan 28, 2011
Make an ipod work
Is it compatible with your iPod?
Oct 17, 2014 | Kicker Ik501 Digital Stereo System For...
My kicker iPod docking station displays aux-in and won't play the iPod there is nothing plugged into the aux jack point
Turn rotary control counter clockwise to disable auxiliary input. When auxiliary input is disabled , menu will display "--".
Jun 30, 2012 | Kicker IK150 Digital Docking System w...
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Kicker zx1000.1 stopped working completely. I have 3 Kicker 10" cv subs hooked to it. The first time it shut off I turned the system off. When I turned it back on it worked for a few minutes and...
First check to see if your'e getting power to the amp by using a test light and touch the main power(12V battery) connector on the amp, test light should come on since it's constant 12v supply. Now turn on the radio and test the remote wire connector on the amp and you should have 12V(test light should come on). Also make sure that you have a good connection with your ground wire, check both connection points to make sure it's good. Now if you have power where your'e suppose to and when your'e suppose to and the amp does not power up, then it may be time for a new amp. Try wiggling the connections at the amp a bit, the solder may be cold/loose.
Jul 12, 2011 | Kicker Car Audio & Video
My kicker L7 subwoofer stopped working??
Is it locked up??? when you press on it is it smooth or does it feel like it is catching??? If so it is shot. If it is smooth though you may have a piece of tensiel popped loose from it flexing. Look at the pos. neg. post on the speeker you will see two wires that go into the cone one or both may be broke loose if so they can be sauterd back on by a qualified audio shop. The question is are you sure it is your speaker and not the inline fuse or the fuses on the amp or even a blown amp??
Nov 07, 2010 | Kicker Car Audio & Video
I can not transfer records from tape to pc for editing
I'd like to share my experience with u.
I have an outdated SONY HC-32 mini DV .At first,I had difficulties connecting my cam to my PC.After lots of fuss&buzz it turned out to be the faulty FireWire port at the docking station.Doesn't cost much to fix,but genuine parts (that darn port) was not available.it is then necessary to do some modifications to use compatible parts instead.
No,no,no.problem not completely solved,not yet.
I then could get connections.But it was totally unstable&unreliable.After another lots of fuss&buzz,this time it was the faulty FireWire card that I installed.Replacing with the new one (same kinda cheapo made-in-Chinese card,but different brand) the problem is now permanently gone.
Hope this helps.
Aug 07, 2010 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a JVC GR-D34E Mini DV , but no software installed. Is that the reason it doesn't detect that the camera is attached to the computer while i try to download movie?
I then could get connections.But it was totally unstable&unreliable.After another lots of fuss&buzz,this time it was the faulty FireWire card that I installed.Replacing with the new one (same cheapo card,but different brand) the problem is now permanently gone.
Hope this helps.
Jul 24, 2010 | JVC GR-D34E Mini DV Digital Camcorder
My amp would turn on and off and one time it just stopped working its a powerful amp want to fix plz.help
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Contact Kicker to have them repair. .A thumbs up would be greatly appreciated if this answer is helpful to you.
May 20, 2010 | Kicker KX500.2 Car Audio Amplifier
Kicker sub wont work
Im guessing that it is possibly blown... either you ran too much power to it, or it was hooked up wrong... you should unscrew the sub from the box and look inside to make sure that it is connected correctly.... positive to positive, negative to negative,,, if they so much as touched then the L7 could very well be blown.... smell the magnet and if you smell a burnt smell... it is blown... maybe turn your amp down a little... its possible that it is also in protect mode because you are running too many watts to the amp. Feel free to ask if you have any other questions.... Please rate! :D And good luck... i really hope its not burnt out. that stuff is not cheap.
Dec 29, 2008 | Kicker Car Audio & Video
Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Dec 28, 2006 | Kicker (ZX750.1) Car Audio Amplifier
Kicker Ik501 Powered Ikick Iphone Ipod Speaker Dock Logo
47 people viewed this question
Top Kicker Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kicker Audio Player and Recorder Expert? Answer questions, earn points and help others
