Question about Jenn-Air Grilling
Uneven burner We are having the same issues as everyone else with 2 burners very low and the third not on at all. We changed the brass burners and still the same problem. We were told by jenn air that the only other thing it could be is the regulator. We changed that as well and still the same problem. We have the Jenn Air 720-0163 pruchased from Lowes. At $770 it is a bit too costly to put out for the garbage but that is what we fell like doing!!! Any help would be appreciated.
    Scholar:
    New Friend:
  • 80 Answers
I apologize I've not logged in for some time and do not know what "everyone else" has had issues with.
I can tell you as a grill repair company we get 4-5 calls every week from clients complaining of poor flames, poor heat. The problem has a very simple solution and the problem is not the burners or other parts and (almost never) the regulator.
There are 3 safety features in an LP cylinder. One is a check valve that gauges pressure leaving the tank. This is a swing-arm pressed up by escaping LP. When the gas fills the manifold and gas line (because the BBQ valves all Must Be Off when the cylinder is turned on) the pressure pushes this swing-arm back into position.
The problem usually occurs with newly filled tanks because with the tank full and the OPD float displacing liquid pressure the gas "hits" the check valve swing-arm too hard so instead of registering the pressure leaving the tank the swing-arm is pressed too far and the back-pressure does not reseat it correctly.
The mechanics of the tank are designed to read higher pressure leaving and lower pressure returning as a leak and shuts-down. We still get some flow because of the OPD pushing but the tank will not allow gas flow at the necessary BTU's.
Reset: Turn off everything on the BBQ and the LP cylinder. Disconnect the cylinder and turn the BBQ valves all to "high".
Wait 5 minutes.
Turn everything off again -- and be sure every valve is completely off so no pressure is released.
Reattach the LP cylinder to the regulator and turn the tank on -- very, vert slow for the first full rotation so the gas pressure leaks through slow and cannot "hit" the check valve too hard.
Once the cylinder os all the way on light the BBQ and it will be fine.
Please let us know how it goes.
If I had one dollar for every time someone contacted us to buy burners, regulator, etc only to fix their BBQ while on the telephone with us ... I would retire!
Posted on Feb 10, 2014
  • 32 Answers
SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
SOURCE: Jenn-Air grill half burner issue
Re: only one side lighting, it is a problem with the cross over **** that carries the flame from one side of the burner to the other. It is located at the rear bottom of the burner and is probably clogged. Wire brush them to clean; failing that, replace with new ones and keep the new ones cleaned with a wire brush regularly.
Posted on Jun 12, 2009
  • 57 Answers
SOURCE: i have a jenn air 3 burner grill purchased 4 years
it sounds like it is a natural gas grill instead of propane change out your orifices
Posted on Aug 27, 2009
  • 11 Answers
SOURCE: Jenn Air grill burners only lite on one side
It could be a bad regulator but,highly unlikely . Check your air shutters at the end of the burner tubes and adust them properly.And if you have a OPD propane tank you maybe turning it on to quick causing the check valve inside the gas valve to open half way. Try opening the valve slowly.
Posted on Nov 02, 2009
SOURCE: grill jenn-air will not heat past 100 degrees
how do you remove burners from Nexgrill 240-0047?
Posted on Jul 17, 2011
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
The flames are uneven, i have the ceramic v shaped covers fror the burners, not charcoal or rocks. the heat is all at the back, it gets very hot there and is corroding the burners and the ceramic...
What you have is a bad case of clogged burners. At least the ends closer to you. This will require removing & cleaning the burners and the venturi valves (part of each burner) to thoroughly clean them
This will also provide you a closeup inspection of all the burners for any accessive wear, or rust thru.
Once the burners are removed, use a brass bristle brush to clean the exterior of the burners and then gently yet firmly tap them on something that want damage them, Then turn them so the open end is down and any debris will fall out. Also clean the Venturi valve on each burner. It will be on the burner tube, where it fits over the burner orifice. It will look like 2 slots (1 on each side) cut out of the burner tube. Spiders like to build nest in them. After you have completed all of that, reinstall the burners, turn the gas tank back on Very, Very Slowly and give them a test. You should see a significant difference.
Hope this helps you solve the burner problem. Please let me know and Happy Grilling!!
Jun 19, 2011 | Tuscany TGR30 Grill
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
Apr 08, 2011 | Viking Kitchen Ranges
I have a 3 burner spirit grill. I can light the grill, but only burner 3 gives me a nice even line of blue flame. Burner 2 seems to be the worst with oranges flames on the right and left end. Burner 1...
Charcoal and grease build up can restrict even the best gas burners , my suggestion is to clean your gas burners with a burner tip tool . You can purchase these at Lowes or Menards . Here is a website for you to visit to get the ideal . http://www.metaltech.com.sa/victor/tips.htm
Goodluck
Electrician by Trade
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
Only two of 5 burners will work at any one time.
Your problem lays in one of two area's.
Either your regulator needs adjusted or most likely it is your LP tank
Look in the tank fitting for a small brass ring It will have 2 small slots on either side. This ring can back off over time and then will not allow the male fitting to fully depress the valve in the tank thus reducing your gas flow. I have had this happen on several tanks a bit of caution and a small flat bladed screw driver has always fixed the issue
Mar 13, 2010 | Grilling
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Low flame on burners
Check the following items:
The propane regulator - and make sure the valve on the propane cylinder is all the way open
The fuel jets (the holes at the end where the propane comes out, usually brass)
The manifolds - they can become obstructed with insect nests
The gas burner valves
The burners themselves, again for obstructions
Apr 19, 2009 | Kitchen Ranges
Uneven burners
you nailed it,you have to clean the burner ,and yes dont be afraid to soak it in soapy water in the sink to clean,the holes around the burner are blocked,could be from an accidental boil over,also clean the others while your at it,let dry and reinstall please rate this solution thanks
May 27, 2008 | Whirlpool GS460 Gas Kitchen Range
Grilling Logo
114 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
