Question about Nikon Cameras
Nikon lens 35-70 af zoom ring stuck
Zoom ring stuck at 70 mark
    Guru:
  • Nikon Expert
  • 362 Answers
This is not a do-it-yourself type of repair. If you try to do any disassembly of the lens yourself, you will end up with a table full of parts you will not be able to properly reassemble and it will cost twice as much to have it fixed. Send the lens to Nikon or a professional camera repair man.
Posted on May 11, 2014
  • 37 Answers
SOURCE: tokina 35-300mm af zoom lens
Unless you have extensive experience, this is best left to professionals. If you didn't spend much, then you could "learn" on it, but if it is something you really value...don't do it.
Posted on Nov 03, 2007
  • 146 Answers
SOURCE: Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Posted on Jul 04, 2009
  • 37 Answers
SOURCE: My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
Posted on Jul 13, 2009
SOURCE: I dropped a Sigma 70-210 AF Nikon mount zoom lens.
sigma af apo 75-300 zoom lens gone cloudy inside front lens . can it be cleaned out if so how
Posted on Sep 02, 2009
cammedic
  • 667 Answers
SOURCE: I have a Quantaray 28-200 mm f/3.8-5.6 AF Zoom
The Nikon D40 requires the use of AF-S/AF-I lenses. Here is a chart of lens compatibility for Nikon SLRs:
Nikonian.org
Posted on Dec 15, 2009
I have a Quantaray 28-200mm AF zoom lens Nikon, I use Nikon D80, are they compatible?
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Jul 14, 2014 | Quantaray 28-90mm F3.5-5.6 Autofocus Zoom...
Sticky zoom ring on a Nikkor 18-55 AF-S Zoom. The zoom gets jerky at the 18-24 mark. I think it needs some lube but I don't know where to put it?
You would have to disassemble the lens barrel to get to the zoom sliders, and lubrication is not likely the problem anyway. The zoom mechanism uses nylon bushings sliding in a groove, and zoom problems are usually due to wearing/cracking of those bushings.
If it's still in warranty, send it in. Otherwise, the cost of repair probably exceeds the value of the lens. Sorry.
Aug 05, 2013 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
The zoom ring has limited use...maybe something stuck inside lens
If you are unable to maximize the zoom capabalities of your lens, the mechanical gears might have been jammed and or broken. Do not push it if it won't let you as you might break the lense. What you can do is to bring it to your local camera shop or service center to have it fixed.
Jun 09, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Hi, can tell to me why my 18-200 af vr lenss go
The "problem" is that the lens has a zoom creep issue. If you are the original purchaser, and the lens is under 5 years old, you may want to contact Nikon repair facilites in Melville or El Segundo to have it checked out.
Some users on forums have claimed that Nikon fixed the plastics ring that contribute to the zoom creep. Apparently, using a rubber band around the zoom ring will minimize the problem.
Hope this helps,
Andrew
May 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Replacement rubber zoom band nikkor 17-55 2.8
yes...check with Nikon or I have seen replacement rings on ebay even...I'd check with nikon or a local nikon repair facility for parts..
Jan 25, 2010 | Nikon Zoom-Nikkor 17-55mm f/2.8G ED-IF...
Don't force it.
Jul 12, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Nikkor AF 18-135 lens won't retract fully
The Zoom ring maybe stuck on something, or not aligned properly Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Jun 01, 2009 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
For Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor Lens I need instruction book. Specifically, there are dots side by side marking the apeture selected, left one yellow, right one green, what one is correct and...
The green mark is the index for the aperture setting at 24mm, the yellow mark is the index at 50mm. These really only matter if you are setting the exposure manually and using an external meter. The green mark is the primary mark -- as you turn the ring you will notice that it lines up with a number at every clickstop, while the yellow one is a bit off.
The pull down lever you ask about is the aperture lock. Autofocus film cameras and all digital cameras expect the lens to be set at smallest aperture (highest number). They will give an FEE error if it is not set correctly. When you turn the aperture ring to smallest aperture you will be able to slide the white dot into position next to the orange mark, and that will lock the aperture ring so that it is not accidentally tgurned while using or changing the lens.
Feb 22, 2009 | Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor...
Cameras Logo
241 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
