Question about NAD C521 CD Player
Nat C521 CD player- button stuck
Hi. I've managed to press the play button too hard and its now stuck into the machine. Is there way to unstick it?
How to insert cd into dell c521 tower
Anonymous,
You can press the button on the front of the cdrom and the cd drawer will open.Insert the cd and then you can then press the button to close.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Oct 14, 2014 | Dell Dimension C521 PC Desktop
PLAY/PAUSE Button issue Hi, got a problem with an CDJ 1000 MKI when i put a cd on it , and starts playing i try to press the play/pause button it will freeze and will have to reset the machine, have...
Yes, this can be caused by a faulty button or buttons, where they are stuck in the on position. The control line gets blocked by the stuck button, and won't even eject in some cases. Take it to a service centre and they should be able to resolve it while you wait, and drink their tea :)
Aug 19, 2011 | Pioneer CDJ-1000 CD Player
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
Zen mozaic has frozen and now it won't even turn off, have tried pressing all the buttons but nothing happens
Did you try the reset button on lower left side of player? I use a twist tie and cut paper or plastic off tip to press button.
Nov 15, 2009 | Creative Labs Creative Technology Zen MP3...
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
Apr 17, 2009 | 2002 GMC Envoy
Nad cd player cd541i noise
Hi...
That one is going to need Tech service.
I've worked on several of the NAD players.
Sounds like a focus or gain adjust needed.
Feb 14, 2009 | NAD C521 CD Player
CD Player in Acura TL 3.2 2003
It's not that hard to fix it yourself.
for your 2003 TL
1. first remove the CD player (this is the hard part).
2. with the CD player removed, unscrew the top cover (4 or 5 screws) on the CD player.
3. with the top cover removed you can see the stuck CD.
4. all you have to do now is just push the CD out and reinstall
should be the same for your 04 TL but im not sure
Feb 12, 2009 | 2004 Acura TL
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
NAD C521 CD Player Logo
46 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
