Question about Honda Garden
Pressure washer needs oil
What type of oil is needed for this motor?
  • Honda Master
  • 3,961 Answers
10W-30 engine oil. Synthetic is often recommended.
Posted on Feb 11, 2014
  • 1388 Answers
SOURCE: type of oil to use
I worked at a tool rental center while attending college and learned all about a variety of tools. We used hydraulic oil with anti-wear and rust inhibitor additives in our pressure pumps. Check at you local auto parts for this type of oil.
Posted on Dec 27, 2008
jj505
  • 195 Answers
SOURCE: power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Posted on Apr 14, 2009
  • 272 Answers
SOURCE: I am wondering what type of oil to add to my
They sell 'pump oil' I use the PRO JET brand universal pump oil. It can be hard to find. I get it from a local chain saw shop that sells pressure washers.
Posted on May 10, 2009
SOURCE: PRESSURE WASHER OIL
non-detergent oil
Posted on May 26, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
What type of oil for XL honda motor with Cat pump
the motor 30wt oil or 10- 30wt, the pump takes pump oil or 30wt
non-detergent, so the answer is no they don't take the same
Sep 14, 2014 | Honda Garden
Oil type 2400psi
any hosue holdcar motor oil will work
Dec 31, 2013 | Briggs & Stratton 3000 PSI Pressure Washer
What type of oil to use
for the motor you need to go by manufacturer's recommendation most pumps use 30w non-detergent oil with the dip stick screwed in
Oct 14, 2012 | Powerwasher 2400psi 2.0gpm Pw2420 Gas...
What type of motor oil
4-Cycle Engine Oil (SAE 30 or SAE 10W30)
Here is a link to the owners manual, should you need it.
http://www.blackmaxtools.com/product_manual/file_url/6/BM80913_485_trilingual.pdf
Mar 05, 2011 | Honda Black Max 2600 PSI Pressure Washer
When adding SAE 30 oil to new pw, do we add to the pump reservoir only or do we also add to the two oil inlets on either side of the engine housing?
From what i've read in the manual you need to fill both the pump and the motor. The pump itself will have a dipstick, the motor gets filled to the top. If the motor has two inlets one should fill up when you pour in the other side. Most briggs had two motor oil inlets so the motor could be used on several types of equipment. The pump itself should use about 9.6 oz
Mar 03, 2011 | Briggs & Stratton Prosumer 2800 PSI (Gas -...
I would like to know if this pressure wahser use only gas or (Gas and Oil) is mixed?
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
Oct 15, 2010 | Dewalt DPD3300 Commercial Pressure Washer
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
Mcculoch power washer fhh18a
I am going to post this as a solution due to the link below but if you still need help just respond here and I will get back to you.
The motor does not require regular oiling as it has oilite bearings. Are you having a problem with low motor speed during use but still have high pressure? Please if you could elaborate on why you think you need to add oil to the motor I think we can solve the problem.
You can read this thread as to what to do: http://www.fixya.com/support/t4707030-shuts_off_when_high_pressure_wand_attach
Thanks for using FixYa.
Kelly
May 03, 2010 | McCulloch FHH18A Electric Pressure Washer
Need to know type of oil DeWalt pressure washer 3800psi
Pump is specialty pump oil available at Home Depot. Engine is 10W 30 motor oil.
Mar 16, 2010 | Dewalt 3800 PSI Pressure Washer
Garden Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
