Question about Adidas Candy Digital watch
Light not working - Adidas Candy Digital watch
Light doesnt work
battery could be low, i have had a similar thing happen with a large face rip curl watch, works fine until you press the light button, theres not enough current left to run the face and the light. mine was almost new too, so even if you just got it it could be that!
Jan 17, 2014 | Ripcurl Rip Curl Trestles Oceansearch Tide...
Nixon rotolog light doesn't work
looking for the owners manual to the casio edific EFR-513sp watch
Jul 21, 2013 | Nixon Watches
My watch stopped working. It's been in a jewelry box for a few months, no exposure to light. What do I do?
Eco-drive watch should work for 1 year out of light. Take it out of the drawer and place in light, and check that the pin on the side is pushed in all the way.
Dec 04, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
I have a elgin steel PQS watch. I haven't wearn it in a year. When I took it out of my dresser it no longer was working. What should I do? How can i get it running again.
This is a solar powered watch. I have placed mine under an incandescent light over night and it has started working again. Fluorescent light will not work. It needs to be out in the light whenever possible.
Aug 16, 2010 | Bulova Watch
Watch stopped working
I fixed my problem by pulling the crown out to position 2 and then put it in the light, cause I tried to put it in the light without pulling out the crown but it would not charge
May 02, 2009 | Watches
Brake light switch not meeting brake pedal
The brake light switch should be adjustable in as much as you can screw the switch holder around until it is the required distance from the brake pedal - the switch holder should have a locking nut, which requires undoing first then locking back once you have obtained satisfactory adjustment,thats assuming that the switch itself isn't broken or faulty.
Feb 10, 2009 | Beverly Hills Polo Club 22-710TTS
Light won't work
I suggest you have to check your battery first. It may be underpowered. Replace it with the new one and then check light again.
Dec 19, 2008 | Polar F6 Wrist Watch
Keeping time and indiglo light not working
check to make sure the button is making contact with the circuit board. It may need to be adjusted. Try and manually make contact with the copper contact. If it lights, then just adjust the tab.
Oct 15, 2007 | Timex 27191 Wristwatch
Adidas Candy Digital  watch Logo
20 people viewed this question
Top Adidas Watches Experts
Ansel Alberto
Ansel Alberto
Vuk B
Are you an Adidas Watch Expert? Answer questions, earn points and help others
