Question about Nespresso Coffee Makers & Espresso Machines
I accidentally tried to run my Nespresso maker without the water tank in and now it won't **** water through the machine when I put the tank back on.
No water is getting from the tank to the machine.
mirran
  • 515 Answers
SOURCE: Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Posted on Jul 10, 2008
SOURCE: Nespresso C1OOB not sucking water out of the tank anymore
I had the same issue and spoke to Nespresso this morning.  To solve this you need to reprogram-put a capsule in the slot and place a cup on the drip tray-press and hold the lungo button until the coffee has reached the desired height in the cup and then release the button.  That should work and every time you make a lungo cup it should be that amount. Hope this was helpful.
Posted on Oct 23, 2008
SOURCE: Krups XP9000 won't recognise water tank is full
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Posted on Mar 08, 2009
SOURCE: the nespresso D150 i have will not dispence water
Follow descaling instructions from the Nespresso site; see pdf link below:
http://www.nespresso.com/precom/sav/pdf/User_manual_CLA.pdf
Posted on Aug 18, 2009
  • 21 Answers
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Posted on May 08, 2010
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
Nespresso Maestria pump isn't primed
We had the same problem and were ready to return the device when we were able to fix it. Here is what we did:
1. Fill the water tank all of the way and place in machine
2. Let the tank sit in position for a few hours (we let ours sit for 3)
3. Run the descaling option
4. Run a few cycles of the "longo"
5. If the machine is still not working repeat the process (Ours started to run after the 2nd cycle)
It just appears that the pumps are shipping with air in them and needs patience to get it out. Once you get it going though you won't regret it :)
Dec 20, 2012 | Nespresso Maestria Rosso
Le Cube: Water does not flow after tank in Le cube ran dry....
Open the lever (the one on top of where you put the pod, and keep pressing it backwards until water comes...
May 18, 2010 | Nespresso Le Cube
Not making coffee
Unplug the machine.
Fill the water tank, and drip a little water into the out-spout to prime the pump.
The auto-off feature is designed to protect the pump from running dry and burning out.
*Some models had a reset button on the rear, if yours has it then use it.
Plug the machine back in and give it a try...once the pump sensor acknowledges water, it will reset.
***Don't forget to VOTE for the guys who take an interest in helping!
Apr 30, 2010 | Nespresso C100B Essenza Single-Serve...
I accidentally started running the machine without the water and now it's not working.
The pump will **** air, but just fill the water reservoir and run the machine 3-4 times and it will be ok.
Jan 03, 2010 | Nespresso C100B Essenza Single-Serve...
Leaking water, does not close
I had the same problem with the nespresso krups xn20 machine. After calling the Nespresso service desk they substituted free of charge the water tank, which has a little valve with seal at the bottom. It turned out that the problem was not the seal of the water tank, but the seal of the machine (onto which the water tank is installed).
I solved the problem by using Teflon tape (same type as that used to connect for water pipes) on the water tank, applying it at the appendix which goes into the machine.
It's been working ok since then (couple of days). The only problem could be the wearing-off of the tape after some time (you will have to reapply it).
Apr 17, 2008 | Nespresso C100B Essenza Single-Serve...
Just says 'fill water'
this has happened to me. try opening the steam wand (but without the steam function turned on) to force hot water out. that usually gets it going for me.
Sep 16, 2007 | Nespresso D300 Espresso Machine
Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand.  That should take care of it.
Jul 23, 2006 | Nespresso D300 Espresso Machine
Coffee Makers & Espresso Machines Logo
103 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
