Question about Toshiba 36A43 36" TV
Hi when i do a channel search nothing gets program
    Top Expert:
  • Toshiba Master
  • 75,581 Answers
Sounds like a main memory IC problem. Its main system control IC should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 10, 2014
How do i air tv reception i go to auto program it does channel search but i get nothing
You should SELECT air TV. Maybe you are looking searching Cable TV and you don't have cable service
May 04, 2015 | Televison & Video
I have a uniden bc246t how can i get it to load channels, scan hold nothing stored
Rather than loading frequencies via software, try programming manually, if that's going to be to hard, perhaps getting hold of a copy of the user manual (available from Radioshack or similar store) and it will tell you how in a step by step way.
You must have a list of frequencies in hard copy format to be able to do this, I've never used software to program my scanners, including my Uniden UBCD996T digital scanner, after all, half the fun is programming your favorites manually, so you learn how the scanner works.
I hope this is useful to you.
Cheers,
Peter
Feb 19, 2013 | Uniden BC246T Handheld Scanner
I only get channels 2 through 22, 23 on up - nothing
this is not a problem from remote control. You must adjut the TV program go to the MENu, run the scanner, for add the program TV.Try to reach you supplier TV cable for explain then, if there are not problem witht the receiver box.
however if you need to reset the code program go for free download:
www.fitness.manualsonline.com or www .remotecodelist.com
sincerely. God bless you
May 07, 2012 | Televison & Video
Hi, i have 14 "
As I see it, your problem has something to do with your remote. I bet you have pressed the "auto search" button of your remote that's why your TV keeps on searching channels automatically from channel 76 down. Here's what you've got to do:
1. Get your remote control
2. Turn on your TV.
3. Press the "auto search" button to stop your TV from automatically searching channels.
4. In case it works, I'd advise you to look for channels manually using the number buttons or the "previous" or "next" buttons.
5. If it doesn't work still, contact your technician or your service provider about it. They are of great help for you!
I hope it helps. Thanks a lot.
Jul 23, 2011 | Televison & Video
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
Change channels get no picture or same program
go to menu programmed and choose auto search then press it.pls wait until the searching will finish.
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
Receiving tv programs
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Aug 25, 2006 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Toshiba 36A43 36" TV Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
