Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Remove climate keeper air tower ge arctica dual evaporator refrigerator
SOURCE: GE PRofile Arctica
Got mine fixed!
http://www.fixya.com/support/t867206-ge_profile_pts25lbmarww_power_but_no
Posted on Aug 07, 2008
SOURCE: I have a GE Profile Arctica refrigerator (model#
make sure is the arm in the icemaker is down
Posted on Aug 25, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
  • 10 Answers
SOURCE: GE ARCTICA Refrigerator, M/N PSS26PSTA - poor cooling
possibly low on gas
Posted on Sep 13, 2009
  • 153 Answers
SOURCE: RE: GE refrigerator gts22kcmbrcc, freezer
The tower lifts straight up
Posted on Feb 18, 2010
Freezer n refrigerator is warm at 78 degrees
If the compressor is running it either has broken valves or the refrigerant has leaked out. Without knowing more than the information you've provided I would start with the basics. Does the fridge have power? Can you hear both the condenser and evaporator fans running? Have you checked the coils under the fridge to see if they are clean?
Jun 21, 2010 | GE Profile Arctica Stainless Steel Top...
My ge artica model number pss25ngma the refer part freezes evertyhing. I have adjusted the temp but it goes back to 32 waht can I do?
check the evaporator fan; listen to see if it is running check the baffles between the freezer and, the refrigerator box for air flow. Check the control knob to see if it is turning the cold control shaft. If these are not the problem: replace the cold control
Mar 17, 2010 | GE Profile Arctica Stainless Steel Top...
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
Impala has dual climate control. AC blows cold on
with a dual climate control system, it is imperative for a proper refrigerant charge to be maintained. the symptom you describe is a possible indicator of low charge on the system. the ac evaporator core is closest to the right side of vehicle thereby making air feel cooler on that side, on the left side of the vehicle the cooled air has farther to travel and warms up from cabin air before it discharged from the vents. this is the most probable issue for your vehicle...however if the charge is accurate, the issue would be more so in the air temperature doors which is located deep inside the dash...i hope this helps...good luck!
Jun 09, 2009 | 2004 Chevrolet Impala
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
152 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
