Question about HKC 7" Touchscreen 8GB Tablet 1GHz Android 4.0
Tablet will no longer connect to Wifi
When I try to connect to Wifi the tablet says Authentication problem. I have tried several other connections but it shows the same problem for all.
  • Marlena Byers Feb 10, 2014
    Hi Heather Seago, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Can't connect to WIFI -- keep getting an authentication problem
It depends on the tablet that you have. Usually non branded tablets tends to have lots of problem. It also could be that the radio could be corrupted. Radio is what it take care or manage the wifi, data, etc... anything with connectivity.
I do suggest that your try to flash the radio again if possible. If not, try these next steps:
1. Go tot he wifi connection and tap on forget, this is to make sure that you don't have any wifi saved.
2. Reboot your tablet.
3. Now search for the wifi again, set it up with all the requirement, like password, channels, etc.
4. Wait until it display saved even if it doesn't connect.
5. Reboot your tablet.
6. Try to connect again to the saved wifi. If it still doesn't connect, your only option is to flash the radio band.
Dec 29, 2015 | Tablets & eReaders
I got new gigaset qv830 tablet can't connect to wifi & this is my first android
Android Tablet Wi-Fi Authentication Problem [Solved ...
www.tomshardware.com/.../45501-43-wifi-authe...
Tom's Hardware Guide
Oct 23, 2014 - 20 posts - ‎17 authors
I have a new Android Tablet, it seems to work okay, but I keep getting ... I am DETERMINED to get this tablet connected, though, and when I find ...
Gigaset 8" Quad Core 8GB WiFi Android Tablet w/Google ...
www.qvc.com/Gigaset-8-Quad-Core-8GB-WiFi-Android-Tablet-w...
QVC
Free
This holiday season, wrap up the gift that tops their list with this Gigaset QV830 tablet. Work and play--all from the same device.
Newsmy tablet T3 problem wifi connection - YouTube
? 3:48
https://www.youtube.com/watch?v=PSR9QU2eph8
Jul 31, 2012 - Uploaded by Jan Ochotnicky
Newsmy tablet T3 problem wifi connection. ... grey wifi/cant connect to google play error fix (root ...
[PDF]Gigaset QV830 Tablet - User Manual.pdf - liGo
Dec 26, 2015 | Tablets & eReaders
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
Authentication problem. Reset wifi and tablet. Nothing is working.
An "authentication problem" means that that the wifi does not accept the wifi password that the device is providing, or that its MAC address may be on the exception list, not allowing it to connect. Verify that the tablet is using the proper wifi password for the system you are trying to connect to, and that you are using the same wifi security (WEP/WPA/WPA2) on the tablet that the wifi is using.
Oct 04, 2015 | Dragon Touch Touch R10 10.1 Google Android...
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
How do I connect to my wifi
Hi
A username
A password
An encryption key
Cheers
Nov 17, 2014 | Polaroid 7" Internet Tablet Android 4.0...
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
HKC 7" Touchscreen 8GB Tablet 1GHz Android 4.0 Logo
19 people viewed this question
Top HKC Tablets & eReaders Experts
 Mikey
Mikey
CCervantes
JonSnell Electronic
JonSnell Electronic
Are you a HKC Tablet and eReader Expert? Answer questions, earn points and help others
