Question about Amana AEW3530DDS Electric Single Oven
Some buttons on control panel do not work - Amana AEW3530DDS Electric Single Oven
None of the control panel button work on my GE profile oven is there anyway to reset it
No you will need to replace the entire control panel to correct this, it is all one piece, buttons and board.
Nov 04, 2016 | GE Ovens
I just moved into a new apartment, I can't find the user guide for the whirlpool gold gas oven, don't know how to operate the oven, none of the button works on the control panel, not even the start...
You can go to whirpool.com then click on owner center and download a manual BUT YOU MUST HAVE COMPLETE model number which usually on inside of oven door or in storage drawer
Jul 27, 2011 | Ovens
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
Amana AEW4530DDS cancel button the only button to beep or work on control panel. Time of day lights up. oven wont work . before oven went t/u had it on broil with the door open a bit. did this fry the...
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Mar 16, 2010 | Amana AEW4530DDS Electric Single Oven
I have a Whirlpool RBD275PDS14 double oven. It
Look for a blown fuse mounted on back of the controleb59c28.pngtis page is in the MANUAL
Feb 10, 2010 | Whirlpool RBD305PD Electric Double Oven
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
No power on control panel
No reset for the control panel... you can try a hard reset ( remove power by triping the breaker for 1 min ) most like you have a safety thermo thats blown or a bad control... I can help you find them if you want to take it apart
Dec 15, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
Amana AEW3530DDS Electric Single Oven Logo
18 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
