Kenmore 64742 Electric Dryer
Problem for Kenmore 64742 Electric Dryer
Light comes on but won't turn
By dsmeier03 on Jun 07, 2009
I have a 70 series Kenmore dryer. I had some towels in it the other day, they finally got dry but the outside was very very hot to the touch, more than usual. Smelled like something was burning, but just slightly. The light inside comes on but when you hit the start button it doesn't do anything. I cleaned out the vent line. Any ideas? It is only about 5yrs old.
Comments:
Jun 08, 2009
- Thanks! I've had a fuse replaced a couple of times in the last year but still never seemed to dry completely sometimes. Guess they may have missed the real problem..
Jun 10, 2009
- Yeah, it never dries my towels on the first cycle, maybe it just isn't built for it. I will try to find the parts on the next two days.. Thanks a lot. I already used my blower to clean out the vent line..
Jun 21, 2009
- I just replaced the thermal fuse and it is working. I also used my blower to clean out the lint from the dryer line and blew all the lint from the back of the dryer. The top still seems a little bit hot so I am a bit nervous. I am going to throw some clothes in it and see how it goes. Do you think I should replace the thermostat too just in case?
Jun 21, 2009
- I put a few loads in, seems to dry pretty good. The outside is kind of hot but I don't smell anything burning. I will keep an eye on it.. Thanks for all your help!!!
Jun 25, 2009
- I ran the dryer for about 30 minutes tonight and the clothes were very very hot, as well as the outside. I'm ordering both thermostat's to replace so hopefully that will take care of the problem. I will let you know and thanks again!!
Oct 17, 2009
- It was the vent, it was full of lint. I bought a line cleaner off Amazon and cleaned it out, works great. Thanks
Solution #1
posted on Jun 08, 2009
Not Rated)
erpaalai
Rank: Guru  Kenmore Expert
Rating: 90%, 283 votes
Sounds like a thermostat problem. The operating thermostat was not working properly and now the thermal Fuse is open and requires replacing. If you only replace the fuse and not what caused it it will blow again. Because it was cycling on the Hi Limit that should be replaced as well.
Eric
Comments:
Jun 09, 2009
- You need heat and airflow for the dryer to work. Lack of airflow will create overheating. So will over loading the dryer with large bulky items, sleeping bags, comforters, quilts.
Eric
Jun 10, 2009
- Long dry times have several other possibilities
  1. Poor air flow
  2. Overloading resulting in #1
  3. Washer not spinning out enough moisture
The fuse blowing is a sign of overheating do to, too much heat or poor airflow. Let me know what the problem is when you find it.
Eric
Jun 21, 2009
- Hard to say if really too hot or not without measuring the temp inside the drum with a load. Eric
Was this helpful?
Yes
No
Popular Solutions for Kenmore 64742 Electric Dryer
Questions and Unsolved Problems for Kenmore 64742 Electric Dryer
Do you recommend Kenmore 64742 Electric Dryer?
Answer
Answer
I have cleaned the condenser as per the instructions on the front of the dryer- the light is still... (More)
Answer
Yesterday I turner the dryer on, and it did take more time than usual with the start button pressed... (More)
Answer
The dryer quit heating, but when I put clothes into fluff they up it wont shut off
Answer
I'd hate to buy a timer and find out it's not the problem. Any suggestions?
Answer
I have a 70 series Kenmore Dryer, recently replaced the timer and the heater element. Occassionally... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
