Question about Swanstone QZLS-3322 Granite Large/Small Bowl Kitchen Sink, Granito
Replacing sink with new swans tone
What do I have to use to seal the drain? I have heard not to use plumbers putty and then that I can. Do I use plumbers putty or silicone
    Habit-Forming:
    New Friend:
  • 39 Answers
If you are in need of an emergency plumber look no further than Gauteng Plumbing. They are your 24 hours plumber and are just a phone call away.
24 Hours Plumber
Posted on Nov 08, 2015
    Master:
  • 574 Answers
Being a plumber for 50 years I hate the new fittings . I still use plumbers mate = and boss white , with silicone under faucets .
Posted on Jun 14, 2014
Sink strainer replacement
I cleaned the old putty off and put a thin layer of new putty on and it sealed the old strainer
Jan 09, 2014 | Home
I have installed the bathroom sink according to the directions (which need words along with the pictures) and the drain leaks. I used plumbers putty around the lip of the drain (instructed to by Menards)...
the sink drain through basin. you can use chaulking compound like for tubs. remove drain put a bunch of chaulking on drain outlet of sink, under drain on bowl of sink. let sit for approx. 10 minutes, then replace drain and tighten down. have a good day !!
Jul 11, 2011 | Moen Home
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
What is the proper way to install a BLANCO sink strainer Kitchen Sink COD.100113 I believe is the code # Thank you
Hello, W/D here.
To install your strainer, you'll need some plumber's putty. The old one is removed by loosening the large ring on the underside and the strainer pulls out from the sink side. Once you are down to just the hole in the sink, you're ready to install the new strainer.
Get a portion of the plumber's putty in your hand about the size of a golf ball. divide it into two portions. Take one part, and roll it in between your hands, palms together and vertical, making a rope.
Take your rope, and place it around the sink hole. If you need more putty, roll the other portion in a similar fashion, and continue around the hole. You may need to overlap the rope putty where it's thin and at the ends to make sure that you get a good seal when you apply pressure the the basket. Place the strainer basket in the hole and press it down lightly, just enough to hold it in place. From under the sink, place the gaskets on the threads, followed by yjr large ring nut that will hold it all in place. Usually, there are two gaskets, a paper type, and a plastic type. Put the paper one on first, followed by the plastic, then the nut. Screw the nut down, applying some pressure to the strainer and plumber's putty. Adjust the strainer now, centering it in the depression in the bottom of the sink. Continue tightening the ring nut, pulling the strainer down into the sink, and squeezing the plumber's putty out, making a seal. Get it pretty snug, and wait a minute. The putty will continue to settle in the seal, and you will be able to tighten it some more after it does. Do this several times, and you'll end up with a good seal that will last. Take a regular screwdriver, and trace it around the strainer on the sink side to release the excess putty. You can ball it up, and press it back into the tub of putty, ready for the next time.
Best regards, --W/D--
Feb 09, 2011 | Blanco Sink Waste Strainer / Stopper...
Badger 5 is about 15 years old and is leaking from the bottom -- from the reset button, the plate on the bottom, and around the electric cord. Can I fix it or does it need replacing?
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
We purchased a franke double sink at lowes for $108.00. we cannot get the basket to stop leaking, we've used plumbers putty as suggested but its not working and the sink still leaks. what can we do
Take it back out and clean all of the plumbers putty off. make sure that the bottom of the sink and the basket is clean and dry. Take a good quality silicone caulk and make a 1/4" bead all the way around the basket where it meets the sink. Tighten the basket nut till it gets nice a snug but not os that you spin the basket much. Then let the caulk setup over night. Trim away the excess with a sharp knife from the top and hook up the drain. This will seal a basket everytime. I never use plumbers putty anymore.
Nov 14, 2009 | Franke VNX-120-45 Vision Double Bowl...
I have a new push push drain from mac faucets, and it leaks. I have reversed the rubber gasket that goes under the sink (held on by the brass threaded ring assume that I don't use plumbers putty under the...
The order of installation starting from the top side is the flanged drain then a bead of plumber's putty, and don't skimp on the putty. On the bottom side, first the rubber gasket then the metal washer, finally the locking ring. You must use the plumber's putty between the sink\tub surface and the flange. My mom thought the same thing. She return her drain twice before she asked me why it was leaking:)
Hope this helps.
Sep 11, 2009 | Opella 2-3/8" Push-Push Drain Assembly...
Kitchen sink drain loose
You can probably tighten it from the bottom. But first, get a little plumber putty from the hardware store and put it around the seal from the topside of the sink. As you tighten it down, it will squeeze out a bit, but that is okay. Good luck!
Mar 25, 2009 | Plumbing
Swanstone QZLS-3322 Granite Large/Small Bowl Kitchen Sink, Granito Logo
285 people viewed this question
Top Swanstone Home Experts
Gene Haynes
Tony Crow
Are you a Swanstone Home Expert? Answer questions, earn points and help others
