Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What does F32 mean
This all I get on my washer, What do I do
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
F32 is usual pressure switch failure
Posted on Feb 11, 2014
A code F32 means pressure switch failure, water level will be low.
Posted on Nov 26, 2015
Cabrio clothes washer codes f68 f84 f32 are shown
Before you do anything, Contact Whirlpool service with your model and serial number. There and many recalls on their Cabrio washers for control board problems.
Feb 28, 2015 | Whirlpool WTW6400SW Cabrio Washer
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
My Whirlpool duet displays F32 code. What dose this mean?
F32 code is usually an indication that your washer is taking too long to drain. Remove the bottom panel and turn the sump trap counter clockwise to remove a sump cleanout. Have some towels ready. Your sump trap is probably filled with lint, coins, buttons, etc. Fyi: wear a closepin on nose for smell!
Oct 19, 2014 | Whirlpool Washing Machines
What is an F32 error code
F32 means the pressure switch may be bad. Take the top off the washer by removing the 3 screws along the back. Next, locate the pressure switch, it is the part in the back left of the machine with the small plastic tube attached. Pull the tube off and blow down it in order to clear any lint in the tube. Make sure all the tiny wires are not stripped and are properly connected into the pressure switch. Check to see that the cables running from the switch to the washer are properly connected. Try running an empty load of wash to see if the switch malfunctions again. If you are still having the same problem replace the pressure switch.
Feb 27, 2011 | Maytag Washing Machines
Washer is throughing a code
Here's a solution from an old posting of the same problem in a different Kenmore washer:
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing thethree screws in the top back of the washer.
2.Inside the back rightcorner is a round plastic box, fastened to the side with a plasticsnap. In will have a wire connector and a small, rubber hose connectedto it.
3. Check to make sure all the connector wires areconnected and tight. Unplug washer for 30 seconds to reset it. If the cycle failsstill with the F32 code, you'll need to replace the Water Level Switch.
4. Ifthe Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Aug 09, 2009 | Kenmore Washing Machines
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
F32 - Kenmore Elite Front Loader Washing Machine
These codes means that the CCU and the CMU are not talking to each other. have you moved lately or some how disrupted the connections from these modules? I don't believe your modules are bad but you'll need to have a technician check and re-secure the connections to your modules and this should solve your problem.
Jul 27, 2008 | Kenmore Elite 45986 Front Load Washer
F32 error code
remove bottom apnel on right side? is tech sheet with codes think f32 is pressure switch
Jul 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite HE 3t washer
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Troubleshooting an F1 to a F32 using the press/hold 3x's process
ALL OASIS WASHERS NEED A SURGE PROTECTOR. IT IS JUST LIKE A COMPUTER .ANY TIME ELECTRIC GOES ON AND OFF YOU STAND A CHANCE OF LOSING BOARD. SEEMS LIKE SEARS WOULD TELL YOU THIS. MAKE SURE YOU ADD THE SURGE PROTECTOR AFTER CHANGING BOARD OR YOU HAVE WASTED YOUR MONEY
Mar 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal De
