Question about 3DO Crusaders of Might and Magic for Windows
Crusaders of might and magic not installing onmy pc win xp
Install issue
Win XP instaling problem on Hp probook 6550b
Hope you are using a fresh windows XP install of the entire system.
HP drivers will need to be obtained and installed before running. The error on the screen usually is a driver error and not a XP issue.
Mar 15, 2014 | HEWLETT-PACKARD HP ProBook 6550b Notebook
I recently picked up an older game, Heroes of Might and Magic IV get home and install. Install wizard runs fine except for one thing despite the fact it correctly identifies all my hardware, it tells me...
I have Heroes of Might and Magic 5 Running on Win 7. There were many patches to install before this title worked(on my computer). Have you installed all the available updates for it?
Here are 2 sites that have the compatibility options:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
If that does not work, you can also try to set up XP mode in Win 7: (Note: you need to have Win 7 Pro, Enterprise, or Ultimate for this one) Win 7 Home Premium does not support XP Mode.
http://arstechnica.com/microsoft/reviews/2010/01/windows-xp-mode.ars/
Jan 29, 2011 | 3DO Heroes of Might and Magic 4 for...
Win XP over win 2007
hia,
you can do by fresh installation; which will format your hard drive and existing windows 2007. and another way; make partition or if you already have then install win XP on seprate partition other than win 2007. if you dont have partition; you can make it by partitioning tools or software like partition magic etc.
now you will need win xp bootable CD/USB; and you need to start your computer with option Boot with CD and if you suing USB then boot with USB.
and just follow step by step instructions in setup and as i said if you want to isntall on seprate partition then select that partition when it ask to choose partition you want to install.
let me know if you need more details or anything else.
Thanks.
Apurva
Aug 19, 2009 | Intel Motherboard
WIN XP INSTELATION PROBELM
some of the hp laptop does not allow you you to down grade to XP but if you like you have to download Easus Partition Magic Software to get the other volume or in other words to split your volume in to two then you have to install XP in other Partition/volume and if you will do that you might not find the drivers. anyways this is the first method. second method is to install virtual server on your machine like virtual Machine or Virtual Pc and use Xp while you are in Vista.
hope it will help you. thanks.
cheerz
Apr 27, 2009 | Microsoft Windows XP Professional SP2
Problem s with Barbie Magic Hairstyler on Win XP
You can try running it in compatibility mode (rightclick the shortclick and select properties)
It may simply not work
Feb 03, 2009 | Mattel Interactive Barbie Magic Hair...
NTLDR missing
In XP, you can load your XP cd and do a repair:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re-installs the Windows files. This is great because when it works you don't need to reinstall all your software.
In Vista , it is tricky. Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | E-Machines eMachines Desktop PC
Install win xp in vista laptop
I went throught the same problem. check out with your hard **** and you will find out that there is the C **** and the D ****. one of them is having vista install and the other one is empty. you can use the magic partitional driver to activate the empty **** and disactivate the vista **** then you can install your win XP. try that it will work out.
Bume
Sep 16, 2008 | Computers & Internet
Installing win xp from external hard drive
Umm...is your laptop crashed??? Usually ntlldr issues ****. try to delete the former installation so a new ntldr file can be installed so as to not conflict with the damaged ntldr file that is on the pc blocking the install. It sounds like your setup is ok...at the very least get another xp cd to make sure the disk is not damaged that you are loading windows from.
Aug 01, 2008 | Computers & Internet
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
3DO Crusaders of Might and Magic for Windows Logo
Top 3DO Video Game Consoles & Games Experts
Paul
Gulkhan
Level 1 Expert
Tom Chichester
Are you a 3DO Video Game Console and Game Expert? Answer questions, earn points and help others
