Question about Infinuvo Vacuums
QQ-2L my vacuum will not charge it just beeps at me when i put on charge. it seems to charge proberly without the battery installed. do you know what is wrong thanks tracey
New Roomba Battery Not Holding Charge - charged once then died
It is possible for the charging system inside the roomba to call it quits. What I did to remedy this, since my roomba was out of warranty and I did not want to scrap it, was to buy a charging base on ebay. This charging base accepts different types of roomba batteries and even the scooba battery. The inconvenience is if you have a newer model roomba that has the battery inside, then you will need to remove the screws on the bottom plate to remove the battery. Hope this helps.
new-roomba-battery-not-holding-charge#solution-section-qgwpio3es2ee0iuiltq5rfxr-1-0.jpg
Jan 23, 2014 | Roomba Robotic Floor Bagless Vacuum
Scooba 5800 starts to charge then beeps loudly
1) test the batteries very well in another device.
2) test the charges if working properly.
3) test the power inside from scuba, some electronic components like diode, or capacitor is draining the batteries. repair or rreplace.
God bless you
Sep 19, 2012 | iRobot 5800 Scooba Vacuum
Roomba red #4100 needs repair does the circle
sounds like you have two different issues here. (Possibly one common)
Clean out the cliff sensors. Under the bumper. blow it out clean. This might stop the reverse circling. The battery is either bad, or the charging circuit is bad. if battery is know good then the problem is the main board needs to be replaced. a bad battery will kill a main boards charging circuit by over working it with shorted batteries
Mar 20, 2010 | iRobot Roomba Red 4100 Bagless Robotic...
Charging error 5 - battery not workiafter 4 calls and 4 different
Generic works fine, and that charger does too. If your charge light and dock light are on then you'll be okay.
Save cash, go generic!
Mar 03, 2010 | iRobot Roomba 560 Robotic Vacuum
Stopped working a few weeks ago - bought and installed new battery seemed to be working OK - now after about a week, it goes for about 15 minutes then stops...
It may need a longer charging period to bring the battery up to full charge. If you have a voltmeter, measure the battery voltage while it is being charged--it should read several volts above the rated battery voltage. If nearly equal, the charge unit may need repair or replacement. Good luck!
Jan 04, 2010 | iRobot 4150 Roomba Vacuum
My roomba 580 runs perfectly for 10 minutes then stops dead without returning to the charger and without the usual beep to notify you of an error
seems like a battery fault.
can you start it after it stops?
how old is it?
try reset and deep charge it
hope that helps
Dec 28, 2009 | iRobot Roomba 580 Bagless Vacuum
The green light is on as though the battery is fully charged, however, when I start a cleaning cycle, it beeps and goes to red immediately without moving.
Remove the battery, hold down the POWER button for ten seconds, then put the battery back in and charge overnight. If it still tells you it's out of power as soon as you start it, it's time for a new battery. http://store.irobot.com
Aug 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
User manual
Hello, I too could not locate the manual. I did however, locate a "video on Youtube on how to use the QQ-2. Link is below.
I hope this helps!
-CBR2009
http://www.youtube.com/watch?v=fR4rfVfd_Pw
Jul 11, 2009 | Infinuvo QQ-2 Robotic Vacuum
My scooba seems to work fine but no longer makes the beeping noise. Several weeks ago the beep was sounding very strange almost like a battery was dying. Now it's not making any noise at all. Is this the...
Your speaker went out. It could be totally isolated. You're not going to be able to determine what's wrong with your Scooba if something does happen, though, because without those beep codes, there's no way for the robot to communicate with you.
If you're under warranty, call support at 1-877-855-8593 and let them know your speaker went out.
Jun 28, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Westinghouse WST1600A Unplugged Cord-Free Vacuum how to condition battery
westinghouse wst1600a I have charged my units and pushed the on button and nothing works. it just beeps green and thats it do you know whats wrong? I also can't find any phone # to call for help do you know any?
Mar 10, 2008 | Vacuums
Vacuums Logo
60 people viewed this question
Top Infinuvo Vacuums Experts
Are you an Infinuvo Vacuum Expert? Answer questions, earn points and help others
