Question about Motorola Radius Cp100 Uhf 1ch Two Way Radio W/charger
Can the freq 156,600 be put in this radio if so how do i do it
  • Motorola Master
  • 1,654 Answers
No, 156.600 MHz is not one of the 27 VHF frequencies available in the CP100 VHF radio. (If by chance you have a typo and you meant to ask about the common frequency of 154.600 MHz, aka green dot, it is available in the CP100 VHF.)
Here is a link to a website with the user guide:
http://www.essnashville.com/CP100-operationsmanual-021407.pdf The frequency chart is on page 34. Programming instructions begin on page 20.
Best regards.
Best regards.
Posted on Feb 10, 2014
Hi my deltaforce is slightly off on ssb you have to be on 27554 and clarifier at 12 30 to be spot on 27555 thanks vince
Use a known good external freq counter, and do the tx alignment. that will put your meter back on showing the right freq when you are..
Jan 27, 2011 | Magnum DeltaForce CB Radio
I have three walkie talkies... Motorala CLS 1110... 2 of them are on FREQ 3 and the other is on FREQ 2.... how to i change the one on FREQ 2 to FREQ 3???
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Dec 23, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
What FM frequency does the radio need to be on to use a wireless Disney Mickey mouse microphone?
Each microphone has a different FM Freq. If you can not find a Freq there is a very small hole in the mic near the Mic switch. You will need a jewlers screwdriver to make a freq. adjustment. Hold down the applause button while very close to your FM radio. Use manual tuning on your FM radio until you hear applause. If there is a local station playing on the Freq you can insert the jewelers screwdriver into the small hole and change the FM Freq for the Mic. You only need to make "fractional adjustments" to change the Freq. setting. Once you make a mic freq. adjustment change the radio freq SLIGHTLY up and down until you hear the applause.
This should get anyone going that is having difficulty with this microphone.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Toys
I have a new RCI 2995DX . that after 1-2 mounths it go's off frek
Have you herd it off freq? Do you have a freq counter? How do you know that the person that told you it sounds off freq don't have their receive off freq?
if its on a freq counter, and shows not off freq, then the radio is not off freq. There is some other problem.. Or no problem because if it is just some one else saying it, maybe they are just too picky.
Things that could cause your audio to change. If its in your mobile, diving around will make your audio sound different to people. Antenna or feed line problems. If there is a problem with your antenna or feed line, it could make your audio sound bad or off to some one else.
Also, if this unit has been modded, has the clarifier been unlocked? if so that will change your TX freq.
If the unit is new and nothing has been done to it, there should be no reason why it is off freq unless some one has done something to it.
Feb 24, 2010 | Cobra 29 LTD CB Radio
Help me put new Frequencys in my scanner
Here is the link to all Uniden scanner manuals:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Also, you can find the frequencies for your area at www.radioreference.com.
May 20, 2009 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Constant tone on an HT1000
You will get a constant tone on any channel that isn't programmed. it sounds like the previous user ha a freq programmed on channel 1. Channel 11 is strange, but possible. Usually guys program these radios in order.... they don't put 2 freqs in soo far apart from each other..... I would expect channel 1 AND 2 to have freq programmed in them.... but channel 1 an channel 11 is strange... but possible. Anytime you don't fill up all the channels on these radios (commercial radios in general) you will get a constant tone on the channels that don't have anything programmed in them. Program the radio and your good to go. If you don't program freqs into al the available channels, expect to hear that "constant tone" on any unprogrammed channels. The channels that you hear a tone on do not have a freq programmed into it. Its normal. Good luck
Jul 05, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Freq lock up
If you have programming cables and SW you can program a freq. in the center of the band,in slimplex. Question, can you read this radio?
Mar 01, 2007 | Motorola MT1000 Compatible 2 Way Radio...
Motorola Radius Cp100 Uhf 1ch Two Way Radio W/charger Logo
91 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
