Question about Cycling
My steering his still and cranky I think my bearings have gone not sure how yo undo the head case
The bars feel still and makes a cranking noise when moved, I think the bearing have gone but not sure how to remove them from new bikes.
    Sergeant:
  • 391 Answers
Mark:
I don't know what type of bicycle you have, or how modern it is, but the handlebar and steering head are similar on most models. Try to remove the handlebars and steering head from the bike as a unit. There is a large nut at the top of the head tube (where the steering stem goes into). Loosen this nut, and the handlebars and steering stem should pull up and out of the bearing inner races. When you completely remove that nut, the headset will come apart... (including the fork and front tire which will drop out of the headset. If your brake and shifting cables are too short to let you pull the steering stem completely out of the steering head, you'll need to remove the handlebars from the steering stem. If you are careful, the bearing set, spacers and washer will stay on the fork tube when it comes out of the bicycle frame head, so you will know which order to reassemble them in. Either tag them or lay them in the proper order. Now you can clean the bearings or replace them.
It would be a good idea to clean the bearing races at the top and bottom of the steering head too.
Once everything is cleaned and ready to reassemble, grease the bearings and the bearing races and reassemble. When you tighten the stem nut down, make sure that there is no play between the steering head and the steering stem.
Posted on Feb 15, 2014
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
dunnbiker
  • 8546 Answers
SOURCE: Trek 800 sport needs crank bearings, how to
This isn't Bike Repair 101-level stuff. Take it to a reputable bike shop and have them teach you while they do it. If they're cartridge bearings it's fairly simple. Next time, you can handle it. Be advised, crankset removal tools are specialized and expensive for the casual bike owner who would use them only once every few years..
Posted on Feb 15, 2010
Testimonial: "After more investigation, I strongly agree!"
dunnbiker
  • 8546 Answers
SOURCE: Ball bearings fell out of handlebar connection on 3-speed bike.
Take it to a professional bike shop. They have the knowledge and tools to set it right.
Or take a look at this:
http://www.sheldonbrown.com/headsets.html
The headset nuts were not necessary to be moved for handlebar adjustment. Now the bearing load is too tight. Correct adjustment of the headset requires a delicate balance between tightness and freedom of movement. If your bike has/had the original bearings it's a safe bet they may be due for replacement anyway.
Posted on Apr 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: crank removal for new bearings
Everything you need to know by the makers of the tools you need to own...
http://parktool.com/repair/byregion.asp?catid=61
...unless you just take it down to a Local Bike Shop.
Posted on May 31, 2010
  • 1788 Answers
SOURCE: Bad crank bearings can move crank arms small amount.
clicking can be a stiff link in your chain.
Posted on Aug 04, 2010
How do I stop the squeaking noise when pedaling the bike or using the elliptical option? I've tried lubrication. Only getting worse.
Have you lubricated all moving parts. Wheel bearings Chain and sprockets? Are there fenders if so are they a little loose?. Anything that is loose will vibrate and make a noise. Even dry pedals will make a noise. Crank also.Just a thought.
Dec 23, 2016 | Exercise & Fitness
What might be causing a Noise and rough pedaling from main crank area of the bike?
Sounds like a bearing issue in the "bottom bracket" or the housing that holds the cranks, in other words. I would remove the crank and inspect the bearings. There are several different types of bearings. If your bike uses sealed bearings, your only option is usually to just replace them. a "caged" bearing consists of several actual ball bearings, set into a round metal cage that holds them in place. If you have caged bearings, remove them clean them thoroughly, and then re-pack them with bearing grease before reinstalling. also be sure to clean the bearing cups, or any surface that they may come into contact with. Any dirt, sand, or grit makes for a quick death for your bearings. Some bikes just use free floating ball bearings set into the bearing cups. If this is the case, smear a blob of grease into the bearing cups. This will hold the ball bearings in place while you install the rest of them. Be careful when re-inserting the crank not to knock any of the ball bearings down into the bottom bracket. From the sounds of your description, you may be missing a ball bearing or two. Check to make sure there are no large spaces between any two ball bearings. If you could fit another ball bearing into the bearing cup without crowding any of the others out, then you are missing a bearing. Re-assemble everything as it came apart. When tightening the crank into the bottom bracket, be cautious not to over tighten. The crank arm shouldn\'t have any "wiggle" from side to side, and yet should still spin freely on its bearings. I sincerely hope this helps.
Aug 14, 2014 | Cycling
Life gear exercise bike
This bike looks to be of the Lemond Revmaster series.
first, dial the resistance knob back until the leather break pad is no longer touching the flywheel. Get down on the floor and postion yourself between the flywheel and pedal cranks. Slowly turn the cranks arms and listen and feel for a roughness in the bike.
This has bike has bearings and a belt. It should not make any noise.
Now with the right pedal at a 2:00 position tighten the resistance knob down all the way so the flywheel will not turn. Then get on and push very hard on the right pedal. If the belt is loose, the pedal will move. Austin Fitness Rentals Rent Commercial grade Fitness Equipment in... ">
May 16, 2014 | Exercise & Fitness
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
Feb 03, 2013 | Cycling
I have a 4.0L V6. I have been repalcing the belt about once a year because of wear issues. Now I have a high pitched whine that coincided with the last belt replacement. I think it might be a bearing???...
you may need the tensioner idler pulley that is in the middle of the engine. we have some issues with bearing failure/noise. removed the belt and make sure that the noise that you are hearing is gone
Dec 20, 2010 | 2005 Nissan Frontier
Front crank sprocket clicking on bycycle, when I pedal the front crank sprocket clicks, it isn't the pedals.
make sure all sprocket bolts are tight.
check chain to make sure you have all rollers between links are there.this can make a clicking noise or skip teeth if one is missing when you pedal.
if you feel clicking in the pedals (even if you think it isnt the pedals),then it could be your bottom bracket bearing gone.
put one pedal towards the floor and stand on it.did it click?then try the other pedal.if you got it to click then your bottom bracket is loose
Sep 13, 2010 | Cycling
R1100s 2000 65000miles After a 30min or more run upon stopping a clicking noise comes from the rear of the bike as the suspension moves. This has gone the next morning when the bike is cold.
Possibilities include:
-worn shock bushings
-worn/faulty bearings at final drive pivot point
If you have a center stand for your bike, you can do some diagnostic work yourself with the bike on the ctr. stand.
Try moving the wheel while holding it at 12 and 6 and 9 and 3 O'clock positions. Listen/feel for clicking. This would indicate a loose or defective final drive pivot bearings.
Lift the wheel from the 12 o'clock position and see if the click noise comes from the shock bushings.
Very hard to diagnose without a center stand or service stand.
Good Luck
Sep 08, 2010 | BMW R 1100 S Motorcycles
Feels like type of tank slap when cornering checked tyre headstock tension wheel balance tyre pressures bearings it is the only bike iv'e ever owned that i can not remove my hands from the bars whilst in...
Jack up the front end until the wheel is off the ground, then slowly rotate the bars from one stop to the other. If you hear noises or it feels rough, take the forks and wheel off, disassemble the fork head and inspect the upper and lower bearings and races for damaged surfaces. Clean and repack bearings with fresh grease. Reassemble the fork head and adjust the bearings to just remove slop. Recheck the rotation. When putting the forks and wheel back, check the shock action of each fork individually. If the machine has a lot of miles, drain the fork oil and recharge. Make sure that the axle is clamped tight as well as the fork head clamp and top bolts. Has the bike ever been hit hard in the front? If yes, it could have changed the fork angle making it unstable.
Aug 22, 2009 | 2006 Honda VT 750 Shadow
Hope this helps.
Ed
Apr 16, 2009 | Schwinn Mesa Gs Mountain Bike
Cycling Logo
82 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
