Question about Dell Dimension 2400 PC Desktop
No Picture on the Screen
I am not getting any pictures on the monitor I tried a different monitor no luck !
  • Leonard Lee
    Leonard Lee Feb 09, 2014
    Hi Raymond Tremblay, I want to help you with your problem, but I need more information from you. Do you have a graphics card or is it on board graphics?
    Problem Solver:
  • 7 Answers
Firstly disconnect all the cables from the monitor if connected any, in short monitor should not be connected to any devices. Then press and hold the power button of the monitor for 15 secs and release it. Then try to check it. If still no picture, then try to connect it with another monitor. If still no pic, however you are able to see"no video cable" displqayed on the monitor when its not connected to any devices then the monitor is fine, may be your graphic card on your computer is bad or not working. Please get it checked. Thanks
Posted on Mar 27, 2014
No picture on screen
Try connecting the CRT to a different (desktop or laptop) computer, to confirm that the CRT is still working.
Try connecting a different CRT (or LCD) monitor to your computer, to confirm that your computer is sending video-output.
If possible, try a different "data" cable between the computer and the CRT.
Jul 20, 2010 | HP Compaq FS7600 17" CRT Monitor
I have a Samsung SMT-190 19" FLAT PANEL monitor and the picture won't show but a few minutes and then a sound comes on and the power light is blinking and the picture goes out and leaves only the blank...
More then likey yuor Inverior Board is going bad if not that, Its the Power Board
First check Invertor This Happens a lot Its hard to find someone to fix it.
Well I had a hard time. I just waited and bought one for parts and fixed it Myself
Good luck
PS. You can still use it just get a different Monitor. The Video out on the Samsung to the
Video in on a different Monitor IT WILL WORK
Jul 13, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
HP Pavilion F1703 Monitor Screen Flickers
hi im josh in cebu phils. may i help you friend? just try this solutions i arranged for the people who needs help.just try friend.
Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
WARNING: THIS IS A DANGEROUS PROCEDURE!!!
- Open the monitor casing and loosen the clamp holding he coils around he picture tube. You can loosen them (usually there’s a wing nut) and a rotate the coil assembly until the picture strengthens.
good luck hope i helped you.
Mar 06, 2009 | HP Pavilion F1703 17" LCD Monitor
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Samir
Dec 10, 2008 | LG Flatron L1710B 17" LCD Monitor
try your monitor to other computer or try other monitor to your computer to see where is the problem
Dec 09, 2008 | Computers & Internet
No picture
Try to reverse the cable....use the end connected to the computer at the monitor and the monitor end to the computer. If tapping the monitor doesn't do anything and tapping the cable at the computer does the same faults then I would have it checked or just replace that cable.. Good luck.
Dec 02, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Blank Screen..Will not power off
Have you checked your video source to ensure that this isn't a problem with your PC or whatever you're displaying on it? Try using a different display and see what happens. Try putting this LCD on a different PC and see what happens. If indeed it is this screen then it could be something as simple as a loose cable. Start simple and work from there.
Dec 27, 2006 | Proview XL775I (Silver) 17 in. Flat Panel...
Dell Dimension 2400 PC Desktop Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
