Question about Crafts & Hobbies
Remove glue from indoor outdoor carpet on concrete floor
Glue remover from concrete patio floor where outdoor carpet glue is hard to soften to be able to scrape up and get old glue off concrete
2 Suggested Answers
  • 17 Answers
SOURCE: How do I smooth old flooring adhesive enough to put new floor tiles on it
Depending on the size of the room you should use a floor sander or a buffer with a abrasive pad to smooth the serface to your liking
Posted on Mar 12, 2014
How to Remove a pass and seymour TIM542 floobox
Floorbox is either held with screws or glue ... or set in the concrete floor.
Replacing floorbox can be a problem because the wires cannot be hidden inside a wall or floor without visible access.
Sep 17, 2014 | Electrical Supplies
How to remove PVC glue from polished concrete floor.
I have no idea about this. but i am hiring "IPC Restoration and Renovation Contractors" to renovate my bathroom.
Apr 18, 2014 | Crafts & Hobbies
Mar 11, 2014 | Building Materials
Minimum distance from floor
Hi, the indoor unit should be on a 2' platform, and the outdoor condenser should be on a concrete slab with about 12" all around the unit.
Shastalaker7
A/C, & Heating Contractor
May 15, 2011 | Carrier 38CKC042 Air Conditioner
Building a suncast shed on 10 x10 patio block
IF you're speaking of the hard black plastic floors that come with thes, I'd put it directly on the patio stones. No wood to rot.
Jul 13, 2010 | Suncast 10' X 10' Storage Building
When do I need moisture control for wood flooring?
You need moisture control if laying below ground level or on concrete anywhere as concrete is porous
Jan 03, 2010 | Crafts & Hobbies
Since the last use of my new ProHeat X2 carpet
Check the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool mode). On the underside of this section is a small (about 1 inch square) red plastic piece with a little door on it. Flip open the door and you will probably find it is clogged. Clean it out and you should have full suction again.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to heat gun
When you remove old carpet from a room, you will most likely be left with remnants of glued-down backing on the floor. Getting the tile back to it's original smooth appearance can be a tedious task. You will need to make sure that you have a lot of patience and a lot of elbow grease. Start removing the glue by scraping the tile with a heavy-duty wallpaper scraper or a long-handled scraper. Do a quick sweep of the floor. Plug in your heat gun. Once it is heated up, you will want to place it at a forty-five degree angle to the floor and direct the heat on the remaining carpet backing. The carpet backing will loosen considerably as the glue begins to dissolve. The carpet backing will loosen considerably as the glue begins to dissolve. Use the wallpaper scraper to remove the loosened backing. Work in small sections. Once you have removed the carpet backing from the tile, wash the area with warm water and soap to ensure all of the glue and backing are removed. Continue until the entire tile floor is free of carpet backing.
Aug 27, 2008 | B O X Packaging Two Temperature Heat Gun
Laundry appliance installation
not recommended may cause vibration issue.. my preference ? concrete or tile especially on front loads
Aug 19, 2008 | Kenmore Elite HE4 Electric Dryer
Crafts & Hobbies Logo
75 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
