Question about Olympus Software VG-120 Digital Camera
How do I transfer my pictures to my computer?
What setting on my camera do I have it at when I want to import the pictures onto my computer?
How do I import photos onto my computer
Many cameras were sold with a cable just for the purpose of transferring photos to a computer .other than that you have to put the pictures on an SD card and move them that way .
Mar 11, 2016 | Polaroid Is426 16 Megapixel Compact Camera...
How do I transfer pictures from my Kodak camera to a disc
Install the EasyShare software. Locate the CD-ROM that came with your digital camera. Insert the disc into the CD drive on your computer and follow the prompts on the screen to install the software. If you no longer have the EasyShare CD-ROM, you can visit Kodak.com to download the software and then install it as normal.
Connect the USB cable to your camera. With your digital camera turned to the off position, locate the USB cable that was included with your camera and insert it into the appropriate slot located on either the side or the bottom of your camera, depending on the model number.
Connect the USB cable to your computer. With your camera still in the off position, insert the free end of the USB cable that you connected to your camera to a free port on your computer.
Turn the camera on. Once your camera is turned on, your EasyShare software will appear and it will locate your camera and sync it with the software. If the software does not begin, turn your camera off, wait 30 seconds and then turn it on again.
Select a location for your photos. Once your camera is recognized by the software, a pop-up will appear asking where you would like your photos to be stored. The default selection is the EasyShare folder but it can be changed to whatever location you would like.
Select your settings. Before being able to transfer your photos to your computer, you must select some important settings. These are important settings such as whether you want your digital camera to delete the pictures as they are being loaded onto the computer. You can also select whether or not you want your camera to automatically start transferring your photos as soon as the camera is plugged in. The options will vary depending on what type of camera you have.
Transfer your photos. Once all of your settings are selected, simply press the button that says transfer. Your photos will then begin to transfer from your camera into the folder you selected earlier.
Apr 27, 2011 | Kodak Cameras
I Can't see the pictures or even copy it when I connect it to the computer? what will I do? thanks. GODBLESSU!!!!!!!!
The solution depends upon the Operating System. There are many options for transferring the images from the Camera to the Computer. You can either use the supplied Software for transferring the images to the Computer or with the help of Windows Explorer.
Let's try to set the Camera in PTP/MTP Mode and check if it the computer detects the Camera as a Removable Drive. To set the PTP/MTP Mode, select the USB Connect option from the Main Settings 2 Menu of the Camera.
If the Camera is detected as a Removable Drive in the Computer window, then open the DCIM Folder to copy all the images.
If the Software is installed in the Computer, then the Import Media Files screen of the Picture Motion Browser appears automatically.
Click on Import option to import the images. By default, images are imported into a folder created in Pictures folder that is named with the date of importing.
This should help you in transferring the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
How to download pics. from my camera to my computer
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
Once your pictures are transferred to the SD card it will be easy to transferre onto the computer.
Dec 12, 2009 | Kodak Easyshare C813 Digital Camera
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
Uploading pictures back onto my camera
just copy and paste from computer to the mem card on your camera via my computer
Sep 24, 2008 | HP Photosmart R717 Digital Camera
Importing picture problem !
not with this camera model.
if the pictures are from the computer, you cannot transfer them back to the camera
Feb 11, 2008 | Kodak EasyShare C613 Digital Camera
Importing pictures to computer from camera
Try here: http://www.dll-files.com/dllindex/dll-files.shtml?ptpusb
Jan 10, 2008 | Fuji FinePix S5700 Digital Camera
Olympus Software VG-120 Digital Camera Logo
14 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
